BobMiller
Everything posted by BobMiller
  1. Thanks to both of you for the quick responses. Michel, I was referring to local Ramp/On-Level setup, not a scene setup. Rand, I'll have to try your suggestion next time. I ended up setting up the Ramp/On-Level at the Switchlinc as Michel had suggested. Thanks, Bob
  2. Michel. A related question. I had to swap out a bad switchLinc with a new device. On the old device I had a specific Ramp rate and 50% "ON" level. Within the ISY console I did a swap, then a restore of the new device (to presumably update to the old device state). I can not seem to restore the old Ramp Rates & On Level on the new device. I did a factory reset of the new device and tried several times. Is this possible with the ISY? If not what are the options - do I need to go to HouseLinc? As a follow-on to Jim's question: When I have added this new device (new from Factory) I assume there were no links on the device. But should I have deleted all previous links saved within the ISY and started over again? I am a little unclear as to when you apply your recommendation. Thanks, Bob
