murrolems
  1. Confirmed with the latest upgrade to the alpha firmware (2.7.13) that this is no longer an issue for me with Fios and actiontec. Thanks!
  2. Thanks for the input. Is there anything I can do? Request a new router? I don't want to set up an SMTP relay. It's apparent that this is an issue with the ISY, is there anyway someone can do a compare on the STMP requests. Maybe using ethereal?
  3. I haven't tried that, I'll look into it tonight. Anything special I should be looking for?
  4. What do you mean "what else you have connected"? I just have a PC, an Ooma telephone router and a few wireless clients. I should also note that I couldn't get this to work with verizon's smtp server settings either. Is there something I can change on my router?
  5. I do have FIOS, but I'm not sure if it's an ActionTec router (probably is though). I'll have to check when I get home. Is there something I can try with the parental controls? Thanks for the prompt reply.
  6. I've tried these settings, my own gmail settings, verizon settings. Nothing works. I keep getting a -50001 Mail Server Failure [Connection Failed] when I test. I have 2 recipients in my list. Running 2.7.10 on an ISY 26. I can access my ISY from remote, so I know it can connect. If I try different settings, I get an AUTH rejected error. Help.
