Jay E
  1. Jay E posted a topic in IoX Support
    Is it possible to add an Insteon device without knowing the address? I have some devices from "before UD" that I want to add to the Admin Console, but don't want to go around removing switch plates and hoping the label is still there. Thank you!
  2. Hello! I was lucky enough to have an ISY and PLM as a back up to my Insteon hub. Now to get it up and running! So far it has been going very well. I use an IOLinc to open, close and monitor my garage door. Garage door open = Keypad button on, closed = off. Worked great for years. Now I start messing with the settings to set up a link to Amazon Echo so I can ask Alexa if the door is open. That works properly, however that only works if the sensor is "on" when the door is closed. How do I turn the Keypad button on when the sensor goes off? Looking for any ideas, tip and tricks to take full advantage of what this thing ca do. Thank you!
