DaleSWA
Everything posted by DaleSWA
  1. Bob, Thanks a million, it's working to show armed/disarmed status and control. Dale
  2. Hi, just getting started with Node Servers for my eisy. I installed the TotalConnect NS and had disconnected/deleted it before experimenting with it while trying to troubleshoot a different problem. I reinstalled it in the same slot and now get this error message "Discovery failed please checks logs for a more detailed error". My log is attached. I was sure that when I first installed I could see arm/disarm status, but now the TotalConnect Controller shows no status in the IoX AC. Thanks in advance for advice. TotalConnect_6-4-2024_115206_AM.zip
  3. I have a newer version ON/OFF switch on the shelf. I'll swap it out and see if that makes a difference. One thing I did notice is that for the SwitchLinc in question, right click > Advanced > PLM Communication, the popup says "This device does not support PLM communication settings". All other Dimmer switches show "1 retry".
  4. Hi Javi, I completed these steps and the SwitchLinc status still does not populate in UD Mobile (or IoX AC) using the Local Connection.
  5. Thank you for the suggestions but still no success. I ending up doing the factory reset and restore on the SwitchLinc. No change in the behavior. The SwitchLinc is in IoX and is used successfully in scenes and programs, just can't see it's status if manually turned on or off.. Firmware is at 5.8.3 and UD Mobile is the latest version (1.1.64) in the App Store.
  6. I have a SwitchLinc On/Off whose ON/OFF status is not reflected in UD Mobile when the switch is manually pressed to turn on of off. The only way UD Mobile will show accurate status is if I initiate a query of the device. My other SwitchLinc DImmer switches immediately show their status in UD Mobile. Is this expected behavior for a SwitchLinc On/Off? If not, any suggestions to fix?
