MGustin
  1. MGustin replied to MGustin's topic in eisy-ui
    Nothing was wrong with my network.
  2. MGustin posted a topic in eisy-ui
    So this is the second night and offline. Come on!!!!!!!!!!!!!!!! So if you are offline nothing works - seems like the Insteon Parent Company we all freaked out about a year or two ago on. How about some BCP / Redundant systems? After hour monitoring of systems? Notice?
  3. For what its worth this is what I got from support when I opened a ticket 9 days ago. We are working on a couple of issues. The "rendezvous" error in UD Mobile is firmware related for some, but not all, users and we hope to have a new build in the next week. The "Could not write characteristic" error is being encountered for all users on iOS devices for Matter BLE Wi-Fi commissioning. iOS is blocking communication to Bluetooth for a characteristic (UUID) used by Matter devices. We are looking into the issue with Apple. So, currently BLE commissioning for Matter devices from an iOS device will not work, but Matter should work for IP, Thread, and previously commissioned WiFi devices.
  4. You will only need your API Key. Copy if just in case so you can drop it in the config but yes, you do not need port forwarding anymore once you upgrade. You also need to make sure you have remote access enabled: PG3 remote access must be configured and active. To configure this, login to My ISY, and under your ISY, use: Select tools | PG3 | Remote Connection
  5. MGustin replied to MGustin's topic in Rachio
    Upgraded without any issues.
  6. MGustin replied to MGustin's topic in Rachio
    Confirming 5.0.3 fixed that issue. Thank you.
  7. MGustin replied to MGustin's topic in Rachio
    Found a new issue. When you attempt to stop Rachio from watering it does not (via Programs / Admin). Let me know if you would like logs PM'd.
  8. MGustin replied to MGustin's topic in Rachio
    Just looked; the upgrade to 5.0.2 must have set it to 600. Thanks for making sure.
  9. MGustin replied to MGustin's topic in Rachio
    Will do.
  10. MGustin replied to MGustin's topic in Rachio
    I can confirm that the upgrade to 5.0.2 did the trick. Watering status is now working. Thank you @Jimbo.Automates!!!
  11. MGustin replied to MGustin's topic in Rachio
    Update not showing in the store:
  12. MGustin replied to MGustin's topic in Rachio
    Just resent logs in debug mode.
  13. MGustin replied to MGustin's topic in Rachio
    Same result - PM'd logs.
  14. MGustin replied to MGustin's topic in Rachio
    Mine is not nearly that complex and have been checking at the top level on Watering not at the zone: Front Door Dog Water Sensor Then - [ID 0062][Parent 0001][Not Enabled] If 'Outside / Front Door / Front Door Sensor' Status is On And 'Generic / Rachio-Sprinkler' Watering is Off Then Run Program 'Front Door Dog Water' (Then Path) Else - No Actions - (To add one, press 'Action') So it is checking: The example above looks like it will send the notification in either on or off. I did check the zones just now to see if that is updating in a few seconds. Example I turned on Zone 1 and the Water Status did not update for the zone until I hit query.
  15. MGustin replied to MGustin's topic in Rachio
    Yes - all good on that front:
