SHibbard
Everything posted by SHibbard
  1. Nope it's not, but now I know when doing a factory reset that instead of waiting an hour, I can just monitor that log file...
  2. Case closed. First, the 700 stick is FW 7.17. I did not update it to 7.18 based on the message below (and I agree with him, Simplicity Studio is a PITA). Instead did a factory reset of the Polisy. Then it discovered the stick. Should make that a first task with any problems! Interesting observation: each time I did a factory reset with front button, the system hung forever (SSH access, but Iox not up). found every second that the following was being added to /var/udx/logs/log Sat Mar 22 09:15:35 CDT 2025|/usr/local/etc/udx.d/static/udxops_main.sh: trying to flush context again ... Got back to normal after forcing a shutdown via SSH once I saw those log entries.
  3. Yup, Zooz S2 Stick 700. I had an 800 around that I tried first. When it didn't work I figured ISY didn't support the 800, so yanked it and pulled the 700 that came with the Polisy out of it's box. Hmm, I thought I saw something about NOT updating FW in the Zooz, but not recommending it. Thanks, I'll dig!
  4. @Guy Lavoie Thanks. I didn't hit the Migrate button, since it appeared to be only for the UD module. My Config Screen is below. Looking in Logs, it never finds the stick. The fact that it says it started ZMatter-ZWave has me wondering if it is looking for the module and not the stick. Here's the tail end of the log after a boot: [2025-03-21 18:19:10.689] [I] [iox] [ZMATTER-ZWAVE] IoX StartupComplete() - STARTED [2025-03-21 18:19:10.690] [I] [iox] [ZWAVE-WORKQ-35 ] Started Z-Wave work queue thread [2025-03-21 18:19:10.692] [I] [iox] [ZWAVE-WORKQ-36 ] Started Z-Wave work queue thread [2025-03-21 18:19:10.693] [I] [iox] [ZWAVE-WORKQ-37 ] Started Z-Wave work queue thread [2025-03-21 18:19:10.694] [I] [iox] [ZW-INTERVIEW-38 ] Started Z-Wave interview thread [2025-03-21 18:19:10.694] [I] [iox] [ZMATTER-ZWAVE] IoX StartupComplete() - FINISHED [2025-03-21 18:19:10.696] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Start Z-Wave port detection [2025-03-21 18:19:12.702] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:13.726] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:16.379] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:17.384] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:20.246] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:21.248] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:24.189] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:25.191] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:27.827] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:28.833] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:31.740] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:32.745] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:36.082] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:37.119] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:40.171] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:41.192] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:43.877] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:44.908] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data [2025-03-21 18:19:48.153] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] Requesting device information [2025-03-21 18:19:49.157] [I] [iox] [UZW-DETECT-PORT|/dev/ttyu0] No serial data Tried the URL to deactivate ZMatter-Zwave anyways. After reboot, noticed it had set Config > Z-Wave Support to Auto instead of On. But it still did not find the de
  5. @Techman I'm on 5.9.1, see below. The Z-Wave module is 21100. Z-Wave is enabled in Configuration. Tried disabling rebooting, re-enabling, rebooting, no improvement. I'm just starting with Z-Wave, so I won't have to worry about backing up / restoring. Just adding some smart locks.
  6. Bought my Polisy in 2022, and got it with the Zooz Z-Wave 700 Series USB Stick. Until now just used the Polisy for Insteon, never plugged in the Z-Wave stick. Now trying to use Z-Wave. The Zooz stick is not being recognized in either USB port. With all the work being done for ZMatter, before I dig too deep I'm wondering if the Zooz stick is still supported in current SW? I'm currently running IoX v5.9.1, and I have not migrated to ZMatter Z-Wave, as it looks like that only supports the UD Dongle.
