BMersereau
  1. Circling back. It was a power issue. I'm back in business. I still ordered a polisy and will explore it as I have time.
  2. Thanks. Appreciate the help.
  3. Thanks. The PLM cable I'm using looks like an ethernet cable, is that the serial cable you mentioned? Is this what I need to purchase? https://smartenit.com/shop/plm-serial-cable/
  4. Hi, My isy994i died and I'm considering moving over to a polisy because it is the only option available to purchase. I primarily use it to control insteon light switches and motion detectors via a PLM. Everything else is managed by Home Assistant. Couple of questions: Should I start over from scratch and readd all of my insteon light switches to a clean install? Polyglot 2 or 3, if I'm starting from scratch? If I don't start over from scratch, can I import a backup from my isy994i? What else should I be thinking about? Thanks
