kpurintun
  1. So now I am close to 4 hours. Still can't access the Admin Console. I SSH'd to the Polisy just to see if it would 'disconnect' at some sort of reboot. I guess if' its not good by morning. I should open a ticket?
  2. Hey Guys, Had a lamp go bad. Wiring inside melted until there was a short. Ended up having to replace my Instron switch with a spare. All my 'replace' features worked. Anyways.. saw the 'automatically upgrade to 5.5.9' and I clicked it. it started to do the update. UD mobile sent me a notification that it went offline. Here I am almost an hour later having no idea how to see what is going on. I am fairly new to UD products even though I have had this a while. (Purchased mid 2022).. It's been doing what it was supposed to and working flawlessly with Home Assistant. So, I had no reason to do anything like updates. Anyways, how long is this supposed to take? Is there any way to see what the heck is going on. that something is happening in a 'forward direction'? I have tried to search the forum for a very comforting set of instructions that says "expect an hour of down time" or "you can SSH and type this command to see what the hell is going on"... turns out I have to sit next to it for a long time and wait for some beeps. I have been upstairs and away from it for basically this whole time. so, it may have beeped. also came across the words at the top of the page for previous releases that says, 'please do not upgrade to these versions' and that is where 5.5.9 is. ug. I didn't realize I could upgrade directly to 5.6.2. Have I screwed the pooch? Kyle
  3. Turned out the mutually exclusive stuff was a cake walk.. everything works well.
  4. well.. because it was simple lamps at the end of kpl buttons with simple dimmer changes, I just went with the mutually exclusive buttons and it works well.. i will probably never use these from an app or do anything like that for these, there is no complicated programming. resetting them would be easy. thanks for your help.
  5. So i did a schedule with the devices.. but i should have did it with the scenes.. because then the kpl’s would be in sync right?
  6. So its best to do this with scenes rather than the mutually exclusive functionality? if you set all to ‘non-toggle on’ how do you turn it off? My first use case is our bedroom lamps.. each is a lamplinc turned on with a KPL button.. then there are two preset KPL buttons that set the two lamps to come full on or come on dimmed. I want to be able to turn on lamps individually and off individually.. and then also do the two presets.. but when the lamps are on the presets.. turn off the individual kpl buttons and set dim or bright kpl buttons. the other is my son’s lamp. But just bright and dim.
  7. I have a couple of button groups that i want to do.. set up some mutually exclusive stuff.. but the page where you set it up is covered in warnings.. and an alternate way..but I can’t really find any detail about doing it the better way or what the warnings really mean or if it really matters. do these matter?
  8. Hey Guys, Moving my insteon from 'directly connected to HA', to a shiny new Polisy connected to HA. This all used to be connected to Indigo that did most of the fancy Indigo configs.. (keypad dimming schedules, mutually exclusive keypad buttons, dimming ramp rates and default dim levels, linking, etc..) This has since gotten goofed up in small ways, then moving to HA added extra dumb and removed some of the fanciness. I am super excited about this move and have been eyeballing ISY for a very long time. Anyways. I am trying to plan this out. I don't want to have weeks of wackiness due to me figuring out the ISY insteon stuff. Not sure I want to put my family through this. Its currently wacky but works 80% good. I want 100% good. The most important question... If I have a multiway switch group with 3 keypads as controllers for a lamplinc. Will I just make a single scene with the Lamp as the responder and the keypad buttons as the controller For example, the DS Lamp (far left) in the attachment. This is connected to 3 keypads. If I have a single scene, Will all the buttons and the lamp stay in sync with each other if I turn on the lamp or hit any button in the scene? ..or will I need to create all the scenes to cover each controller>responder relationship.. Lamp to keypads, keypads to lamp and other keypads.. 4 scenes in total? Then finally, what is the best way to get those to stay in sync if I change them from HA? Are there any other things I should consider? Thanks
