CKlamkowski
  1. I got home, pressed the reset pin momentarily— it hung so I did a power cycle and boom—works great. Earlier power cycles did not include the reset pin push, but everything I’d note back to normal— hopefully your experience will mirror mine 👍
  2. Howdy, My polisy is no longer in communication with the UD portal. My subscription was renewed in May for two years, and still has plenty of life left. In ISY, it shows that I am registered but offline, and when I try to revoke the license, I receive an error message: "bad request" I have updated packages, rebooted multiple times, updated java, deleted java cache (all three boxes) and still unable to find a fix. Adding insult to injury, it seems my Polisy reboots now every few minutes--although this might be provoked by trying to revoke the license, that's really the only time I've been actively in ISY; i.e. trying to resolve this issue. ANy and all advice greatly appreciated! PS My.isy.io will ocassionally show my polisy online, but that's short lived, moments later it will be offline (presumably due to the rebooting issue).
  3. Now that they charge per call, how does shortpoll values work? Does the parameter define how many seconds between calls (e.g. 600 - 1 call every 10 minutes)? Edit: Confirming that poll = seconds between calls Should have let my test run longer before asking--thank you for the awesome node--just upgraded to OneCall and it works perfectly 10min after entering in credit card info
  4. Thank you, that worked to login. The latest issue is actually with the OpenWeatherMaps node server, as I continue receiving the same message: query:_get_weather_data: {'cod': 401, 'message': 'Invalid API key. Please see https://openweathermap.org/faq#error401 for more info.'} However, the api key was established 2 days ago, and it works using the 2.5 api via web query (confirmed). Might it be the case that the prior api was depreciated?
  5. Here is what comes up when trying to refresh purchases or even refresh in the node server store...
  6. Howdy, I purchased OpenWeatherMaps on the node server store today. It was installed, but I was unable to have it pull any data. So I deleted it both in admin portal, and PG3--with the intent or reinstalling. However now when I go to purchases, PG3 throws a typreerror and cannot find any purchases. I have rebooted, upgraded packages, cleared Java cache, etc.--to no avail. I just puchsed the node server a second time (paid $5 twice), and the purchase is not coming up in PG3. Any and all advice greatly appreciated, thank you!
