JAvnaim
Everything posted by JAvnaim
  1. Fixed! For whatever reason, Firefox v101.0.1 was the problem (or one of my Firefox plugins)! I tried with Safari and it worked! Thanks Michel for your help!
  2. Thank you for your help; Its greatly appreciated! I'll open a ticket and report back!
  3. Follow up question; I've successfully changed the ISY Password from the default (last week) There was no issue there. Just checking that the auth for Polyglot and ISY are complete "separate" and I didn't miss a step somewhere that I needed to sync them?
  4. I've upgraded to 3.0.63 via SSH, went seamless (no errors noted in CLI). Once the Polyglot v3 portal refreshed, noted it said 3.0.63. I then tried reset password again through Profile -> Settings (same window shown above.) Entered new password, saw green successful messages bottom right corner. Forced a relogin to my.isy.io portal; was successful. Went to login to Polyglot with new password, no love. Same 401 Unauth error in bottom right corner. I am able to successfully login with the default PW. Also no mention of any password reset in the log (successful or errors.) Is there an additional log file I can check via the CLI? Also @MrBill; yes that is the URL shown when I am attempting to change the PW. I'm perplexed!
  5. I just tried it again, same result as I noted above. Looked in the log and it doesn't show any entries regarding a password change, either successful or unsuccessful. Oddly enough, the log doesn't even show the unauthorized 401 error when I try to login with the newly "changed" password (that doesn't work.) Any other thoughts?
  6. Hello all, I am running a new Polisy running PG3 (3.0.62). I am unable to change from the default username / password. When I attempt to do so under Settings -> Profile, it appears to work (green success message bottom right corner.) Then when I attempt to login again, I get the Unauth 401 error and the new password doesn't work. I have to utilize the original/default password again. Thoughts? Jordan
