CManson
Everything posted by CManson
  1. So, overnight, it just started working! Thank you!
  2. Reinstalling did the trick in getting the latest version downloaded and starting the node server. For a minute or two the car appeared as a node but then disappeared? Any thoughts from the attached log? Log.rtf
  3. Here is the main log: 6/18/2022, 16:03:43 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_2] {"shortPoll":{}} 6/18/2022, 16:03:43 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:03:43 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_2 to broker pg3_broker 6/18/2022, 16:03:45 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_DF0Q3 has published message on udi/pg3/frontend/ns/admin to broker pg3_broker 6/18/2022, 16:03:45 [pg3] info: [TeslaEV(5)]: Restarting Node server 6/18/2022, 16:03:45 [pg3] warn: [TeslaEV(5)]: Was not running. Starting... 6/18/2022, 16:03:48 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_6] {"shortPoll":{}} 6/18/2022, 16:03:48 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_2] {"shortPoll":{}} 6/18/2022, 16:03:48 [pg3] info: startNs:: TeslaEV 6/18/2022, 16:03:48 [pg3] info: startNs:: TeslaEV is valid 6/18/2022, 16:03:48 [pg3] error: store get requires a nsid 6/18/2022, 16:03:48 [pg3] error: Node server TeslaEV has no store entry. 6/18/2022, 16:03:48 [pg3] error: TeslaEV automatic update failed 6/18/2022, 16:03:48 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:03:48 [pg3] debug: MQTT Results: [frontend/ns/admin] :: {"restartNs":{"success":false,"error":"automatic update failed"}} 6/18/2022, 16:03:48 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_2 to broker pg3_broker 6/18/2022, 16:03:48 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/d207e2a7-1484-4ed1-9613-8d2d1e1e88fd to broker pg3_broker 6/18/2022, 16:03:48 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_5] {"longPoll":{}} 6/18/2022, 16:03:48 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_5 to broker pg3_broker 6/18/2022, 16:03:50 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_6] {"longPoll":{}} 6/18/2022, 16:03:50 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_4] {"shortPoll":{}} 6/18/2022, 16:03:50 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:03:50 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_4 to broker pg3_broker 6/18/2022, 16:03:53 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_6] {"shortPoll":{}} 6/18/2022, 16:03:53 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_2] {"shortPoll":{}} 6/18/2022, 16:03:53 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:03:53 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_2 to broker pg3_broker 6/18/2022, 16:03:53 [pg3] debug: Client pg3frontend_DF0Q3 unsubscribed from udi/pg3/frontend/clients/d207e2a7-1484-4ed1-9613-8d2d1e1e88fd/log/00:21:b9:02:54:be_5 6/18/2022, 16:03:53 [pg3] debug: Stopping log stream for pg3frontend_DF0Q3 6/18/2022, 16:03:53 [pg3] debug: Sending logfile to frontend :: /var/polyglot/pg3/logs/pg3-current.log 6/18/2022, 16:03:53 [pg3] error: MQTTS: connectionError: null connect did not arrive in time 6/18/2022, 16:03:54 [pg3] debug: Starting log stream for pg3frontend_DF0Q3 :: /var/polyglot/pg3/logs/pg3-current.log 6/18/2022, 16:03:57 [pg3] error: MQTTS: clientError: 00:21:b9:02:54:be_5 Auth Error 6/18/2022, 16:03:58 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_6] {"shortPoll":{}} 6/18/2022, 16:03:58 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:03:58 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_2] {"shortPoll":{}} 6/18/2022, 16:03:58 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_2 to broker pg3_broker 6/18/2022, 16:04:03 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_6] {"shortPoll":{}} 6/18/2022, 16:04:03 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_2] {"shortPoll":{}} 6/18/2022, 16:04:03 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:04:03 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_2 to broker pg3_broker 6/18/2022, 16:04:05 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_4] {"shortPoll":{}} 6/18/2022, 16:04:05 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_4 to broker pg3_broker 6/18/2022, 16:04:06 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_5] {"shortPoll":{}} 6/18/2022, 16:04:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_5 to broker pg3_broker 6/18/2022, 16:04:08 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_6] {"shortPoll":{}} 6/18/2022, 16:04:08 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:54:be_2] {"shortPoll":{}} 6/18/2022, 16:04:08 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_6 to broker pg3_broker 6/18/2022, 16:04:08 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:54:be_2 to broker pg3_broker
  4. So I can't actually access the log file (see error in attached screenshot) and when I try and start it says "Node Server Start: automatic update failed"
  5. Thanks. I have no issue generating the token, my question is where to put it. This is what I see on the configuration page of the node server. I don't see a help section.
  6. I just paid for the node server and am trying to get it up and running but its not clear where to insert the refresh token? Do I create a custom parameter? If so, what goes in the "key" field? I'm assuming that the token goes in "value"?
