DWeintraub
Everything posted by DWeintraub
  1. That worked. Thank you. 🙂 My next problem is that my Kodi add-on doesn't see it. It first found my actual Hue Hub so I unplugged that and tried again but it did not find it. Is it the port or something else?
  2. I have the same or similar problem. The 'Hue Emulator Controller' shows up on my ISY console but the 'ISY Connected' keeps cycling from TRUE to FALSE continuously until I stop the node. I set the port to 8081 and then tried 8088. I set the IP to 192.168.1.18 and also tried 127.0.0.1 but no change. I keep getting 'ISY Could not receive response from device because of a network issue' and 'PyISY could not connect to the ISY controller with the provided attributes'. Thank you -Dane
  3. I have the same problem. I DID enable XMPP. LOG; 2022-07-01 16:02:14,662 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop 2022-07-01 16:02:14,663 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop 2022-07-01 16:02:14,664 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down. 2022-07-01 16:02:14,666 Thread-90 udi_interface WARNING Controller:handler_stop: Stopping... 2022-07-01 16:02:14,667 Thread-90 udi_interface.interface INFO interface:stop: Disconnecting from MQTT... localhost:1888 2022-07-01 16:02:14,668 Thread-90 udi_interface.interface INFO interface:_disconnect: MQTT Graceful disconnection. 2022-07-01 16:02:14,669 MQTT udi_interface.interface DEBUG interface:_startMqtt: MQTT: Done 2022-07-01 16:02:22,210 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-07-01 16:02:24,759 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.41 Starting... 2022-07-01 16:02:25,240 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.0.59 [ISY: 5.4.4, Slot: 4] 2022-07-01 16:02:25,242 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.18', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2022-07-01 16:02:25,244 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:1888 2022-07-01 16:02:25,251 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2022-07-01 16:02:25,252 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'installprofile': {'reboot': False}} 2022-07-01 16:02:25,306 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2022-07-01 16:02:25,308 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:56:0c:60_4 - MID: 1 Result: 0 2022-07-01 16:02:25,324 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-07-01 16:02:25,431 MQTT udi_interface.interface INFO interface:_message: Successfully set harmonyctrl :: ST to 1 UOM 25 2022-07-01 16:02:28,269 MainThread udi_interface INFO Controller:__init__: HarmonyController: Initializing 2022-07-01 16:02:28,271 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: harmonyctrl not found in database. 2022-07-01 16:02:28,274 MainThread udi_interface.interface INFO interface:addNode: Adding node HarmonyHub Controller(harmonyctrl) [None] 2022-07-01 16:02:28,276 MainThread udi_interface.interface INFO interface:setController: Using node "harmonyctrl", driver "ST" for connection status. 2022-07-01 16:02:28,451 MQTT udi_interface.interface INFO interface:_message: custom data response {'customparamsdoc': ''} 2022-07-01 16:02:28,539 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc 2022-07-01 16:02:28,586 Thread-1 udi_interface INFO Controller:handler_log_level: enter: level={'name': 'DEBUG_MODULES', 'level': 9} 2022-07-01 16:02:28,588 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll 2022-07-01 16:02:28,589 Thread-1 udi_interface INFO Controller:handler_log_level: Setting basic config to DEBUG... 2022-07-01 16:02:28,590 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll 2022-07-01 16:02:28,594 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo 2022-07-01 16:02:28,596 Thread-1 udi_interface INFO Controller:handler_log_level: exit: slevel=10 2022-07-01 16:02:28,599 Thread-2 udi_interface DEBUG Controller:handler_params: enter: Loading {'clear_hubs': '0', 'hub_uniqueid': ' { "name": "HarmonyHub Theater", "host": "192.168.1.159" }'} 2022-07-01 16:02:28,599 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'profile_version': '3.0.1'} 2022-07-01 16:02:28,602 Thread-2 udi_interface.custom DEBUG custom:load: CUSTOM: load {'clear_hubs': '0', 'hub_uniqueid': ' { "name": "HarmonyHub Theater", "host": "192.168.1.159" }'} 2022-07-01 16:02:28,603 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking profile_version / 3.0.1 2022-07-01 16:02:28,604 Thread-2 udi_interface.custom DEBUG custom:load: CUSTOM: -- checking clear_hubs / 0 2022-07-01 16:02:28,605 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'purge': 'Nothing to purge'} 2022-07-01 16:02:28,606 Thread-2 udi_interface.custom DEBUG custom:load: CUSTOM: -- checking hub_uniqueid / { "name": "HarmonyHub Theater", "host": "192.168.1.159" } 2022-07-01 16:02:28,606 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking purge / Nothing to purge 2022-07-01 16:02:28,607 Thread-2 udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving 2022-07-01 16:02:28,608 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server. 2022-07-01 16:02:28,609 Thread-2 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2022-07-01 16:02:28,610 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server. 2022-07-01 16:02:28,611 Thread-2 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'key': 'notices', 'value': {'purge': 'Nothing to purge'}}]} 2022-07-01 16:02:28,613 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo 2022-07-01 16:02:28,615 Thread-2 udi_interface DEBUG Controller:handler_params: exit: config_st=True 2022-07-01 16:02:28,638 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message setController 2022-07-01 16:02:28,639 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING setController 2022-07-01 16:02:28,640 Command udi_interface.interface DEBUG interface:_handleInput: connection status node/driver update 2022-07-01 16:02:28,715 Thread-4 udi_interface INFO Controller:handler_config_done: enter 2022-07-01 16:02:28,717 Thread-4 udi_interface.interface DEBUG interface:addLogLevel: Sending message {'setLogList': {'levels': [{'id': 5, 'name': 'Debug + Modules', 'value': 'DEBUG_MODULES', 'level': 9}, {'id': 4, 'name': 'Debug', 'value': 'DEBUG', 'level': 10}, {'id': 3, 'name': 'Info', 'value': 'INFO', 'level': 20}, {'id': 2, 'name': 'Warning', 'value': 'WARNING', 'level': 30}, {'id': 1, 'name': 'Error', 'value': 'ERROR', 'level': 40}, {'id': 0, 'name': 'Critical', 'value': 'CRITICAL', 'level': 50}]}} 2022-07-01 16:02:28,719 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message notices 2022-07-01 16:02:28,720 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'setLogList': {'levels': [{'id': 5, 'name': 'Debug + Modules', 'value': 'DEBUG_MODULES', 'level': 9}, {'id': 4, 'name': 'Debug', 'value': 'DEBUG', 'level': 10}, {'id': 3, 'name': 'Info', 'value': 'INFO', 'level': 20}, {'id': 2, 'name': 'Warning', 'value': 'WARNING', 'level': 30}, {'id': 1, 'name': 'Error', 'value': 'ERROR', 'level': 40}, {'id': 0, 'name': 'Critical', 'value': 'CRITICAL', 'level': 50}]}} 2022-07-01 16:02:28,721 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING notices 2022-07-01 16:02:28,724 Thread-4 udi_interface INFO Controller:_set_num_hubs: 0 2022-07-01 16:02:28,725 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'purge': 'Nothing to purge'} 2022-07-01 16:02:28,726 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller Reporting set GV3 to 0 to Polyglot 2022-07-01 16:02:28,727 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking purge / Nothing to purge 2022-07-01 16:02:28,728 Thread-4 udi_interface.node DEBUG node:reportDriver: Updating value to 0 2022-07-01 16:02:28,729 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'harmonyctrl', 'driver': 'GV3', 'value': '0', 'uom': 25}]} 2022-07-01 16:02:28,731 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: hubs.json = config/hubs.json 2022-07-01 16:02:28,733 Thread-4 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV10 - 1 :: getting dv GV10 2022-07-01 16:02:28,734 Thread-4 udi_interface DEBUG Controller:set_watch_mode: 1=True 2022-07-01 16:02:28,735 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller No change in GV10's value 2022-07-01 16:02:28,735 Thread-4 udi_interface INFO Controller:_set_num_hubs: 0 2022-07-01 16:02:28,736 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller No change in GV3's value 2022-07-01 16:02:28,737 Thread-4 udi_interface INFO Controller:handler_config_done: Adding known hubs... 2022-07-01 16:02:28,738 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: config.yaml = config/config.yaml 2022-07-01 16:02:28,738 Thread-4 udi_interface INFO harmony_hub_funcs:load_config_file: load_config: Loading Harmony config config/config.yaml 2022-07-01 16:02:28,763 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2022-07-01 16:02:28,764 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: hubs.json = config/hubs.json 2022-07-01 16:02:28,767 Thread-4 udi_interface.interface DEBUG interface:checkProfile: check_profile: force={'name': 'HarmonyHub', 'docs': 'https://github.com/UniversalDevicesInc-PG3/udi-harmony-poly/blob/master/README.md', 'type': 'python3', 'executable': 'harmony_hub.py', 'install': 'install.sh', 'description': "Connect Harmony Hub's to the ISY994", 'notice': 'Your disclaimer here', 'shortPoll': '60', 'longPoll': '300', 'logLevel': 'DEBUG', 'profile_version': '3.0.1', 'persist_folder': 'config', 'discover': True, 'customParams': {'clear_hubs': '0'}, 'credits': [{'title': 'udi-harmony-poly: A Node server for For Harmony Hub and ISY Integration', 'author': 'JimBoCA', 'version': '3.0.8', 'date': 'December 29, 2017', 'source': 'https://github.com/UniversalDevicesInc-PG3/udi-harmony-poly', 'license': 'https://github.com/UniversalDevicesInc-PG3/udi-harmony-poly/blob/master/LICENSE'}, {'title': 'Library: pyharmony', 'author': 'Author: Ian Day', 'version': '1.0.12', 'date': '2016-11-26', 'source': 'https://github.com/iandday/pyharmony', 'license': 'BSD-3-Clause'}], 'version': '3.0.8'} build_profile=<bound method Controller._update_profile of <nodes.Controller.Controller object at 0x803279220>> 2022-07-01 16:02:28,767 Thread-4 udi_interface.interface DEBUG interface:checkProfile: check_profile: saved_version=3.0.1 2022-07-01 16:02:28,768 Thread-4 udi_interface.interface DEBUG interface:checkProfile: check_profile: profile_version=3.0.1 2022-07-01 16:02:28,769 Thread-4 udi_interface.interface WARNING interface:checkProfile: check_profile: Force is enabled. 2022-07-01 16:02:28,769 Thread-4 udi_interface.interface INFO interface:checkProfile: Building Profile... 2022-07-01 16:02:28,770 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller Reporting set GV7 to 4 to Polyglot 2022-07-01 16:02:28,771 Thread-4 udi_interface.node DEBUG node:reportDriver: Updating value to 4 2022-07-01 16:02:28,771 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'harmonyctrl', 'driver': 'GV7', 'value': '4', 'uom': 25}]} 2022-07-01 16:02:28,774 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: config.yaml = config/config.yaml 2022-07-01 16:02:28,775 Thread-4 udi_interface INFO write_profile:write_profile: Loading config: config.yaml 2022-07-01 16:02:28,776 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: config.yaml = config/config.yaml 2022-07-01 16:02:28,777 Thread-4 udi_interface INFO harmony_hub_funcs:load_config_file: load_config: Loading Harmony config config/config.yaml 2022-07-01 16:02:28,799 Thread-4 udi_interface INFO write_profile:write_profile: Writing profile/nls/en_us.txt 2022-07-01 16:02:28,813 Thread-4 udi_interface INFO write_profile:write_profile: Writing profile/nodedef/custom.xml and profile/editor/custom.xml 2022-07-01 16:02:28,815 Thread-4 udi_interface ERROR write_profile:write_profile: Hub list is empty? 2022-07-01 16:02:28,816 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: config.yaml = config/config.yaml 2022-07-01 16:02:28,828 Thread-4 udi_interface INFO write_profile:write_profile: done 2022-07-01 16:02:28,829 Thread-4 udi_interface DEBUG harmony_hub_funcs:get_file: get_file: config.yaml = config/config.yaml 2022-07-01 16:02:28,829 Thread-4 udi_interface INFO harmony_hub_funcs:load_config_file: load_config: Loading Harmony config config/config.yaml 2022-07-01 16:02:28,851 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller Reporting set GV7 to 5 to Polyglot 2022-07-01 16:02:28,852 Thread-4 udi_interface.node DEBUG node:reportDriver: Updating value to 5 2022-07-01 16:02:28,853 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'harmonyctrl', 'driver': 'GV7', 'value': '5', 'uom': 25}]} 2022-07-01 16:02:28,854 Thread-4 udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2022-07-01 16:02:28,855 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'installprofile': {'reboot': False}} 2022-07-01 16:02:28,856 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller Reporting set GV7 to 6 to Polyglot 2022-07-01 16:02:28,857 Thread-4 udi_interface.node DEBUG node:reportDriver: Updating value to 6 2022-07-01 16:02:28,858 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'harmonyctrl', 'driver': 'GV7', 'value': '6', 'uom': 25}]} 2022-07-01 16:02:28,859 Thread-4 udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2022-07-01 16:02:28,860 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'installprofile': {'reboot': False}} 2022-07-01 16:02:28,861 Thread-4 udi_interface.custom DEBUG custom:__setattr__: CUSTOM: profile_version = 3.0.1 ...saving 2022-07-01 16:02:28,861 Thread-4 udi_interface.custom INFO custom:_save: Sending data idata to Polyglot. 2022-07-01 16:02:28,862 Thread-4 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'key': 'idata', 'value': {'profile_version': '3.0.1'}}]} 2022-07-01 16:02:28,863 Thread-4 udi_interface INFO Controller:_set_num_hubs: 0 2022-07-01 16:02:28,864 Thread-4 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller No change in GV3's value 2022-07-01 16:02:28,865 Thread-4 udi_interface INFO Controller:handler_config_done: exit 2022-07-01 16:02:29,033 MQTT udi_interface.interface INFO interface:_message: setLogList response {'levels': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]'} 2022-07-01 16:02:29,268 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2022-07-01 16:02:30,108 MQTT udi_interface.interface INFO interface:_message: custom data response {'idata': '{"profile_version":"3.0.1"}'} 2022-07-01 16:02:30,162 MQTT udi_interface.interface INFO interface:_message: Successfully set key = idata 2022-07-01 16:02:30,276 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2022-07-01 16:02:30,277 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode 2022-07-01 16:02:30,279 Thread-6 udi_interface INFO Controller:handler_start: Started HarmonyHub Node server 3.0.8 2022-07-01 16:02:30,280 Command udi_interface.interface DEBUG interface:_handleResult: add node response: {'id': '82a1cd5a-b74c-4b56-b5f8-90fcd40ecc6e', 'uuid': '00:0d:b9:56:0c:60', 'profileNum': 4, 'address': 'harmonyctrl', 'name': 'HarmonyHub Controller', 'nodeDefId': 'HarmonyController', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'harmonyctrl', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1655166581737, 'timeModified': 1655166581737, 'dbVersion': 1} 2022-07-01 16:02:30,281 Thread-6 udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving 2022-07-01 16:02:30,283 Thread-6 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2022-07-01 16:02:30,284 Thread-6 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]} 2022-07-01 16:02:30,287 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV10 - 1 :: getting dv GV8 2022-07-01 16:02:30,287 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV3 - 0 :: getting dv GV8 2022-07-01 16:02:30,288 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV5 - 5 :: getting dv GV8 2022-07-01 16:02:30,288 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV6 - 60 :: getting dv GV8 2022-07-01 16:02:30,289 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV7 - 6 :: getting dv GV8 2022-07-01 16:02:30,289 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV8 - 1 :: getting dv GV8 2022-07-01 16:02:30,289 Thread-6 udi_interface DEBUG Controller:handler_start: GV8=1 2022-07-01 16:02:30,290 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV10 - 1 :: getting dv GV7 2022-07-01 16:02:30,290 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV3 - 0 :: getting dv GV7 2022-07-01 16:02:30,291 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV5 - 5 :: getting dv GV7 2022-07-01 16:02:30,291 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV6 - 60 :: getting dv GV7 2022-07-01 16:02:30,292 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV7 - 6 :: getting dv GV7 2022-07-01 16:02:30,292 Thread-6 udi_interface.node DEBUG node:setDriver: harmonyctrl:HarmonyHub Controller Reporting set GV7 to 1 to Polyglot 2022-07-01 16:02:30,293 Thread-6 udi_interface.node DEBUG node:reportDriver: Updating value to 1 2022-07-01 16:02:30,293 Thread-6 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'harmonyctrl', 'driver': 'GV7', 'value': '1', 'uom': 25}]} 2022-07-01 16:02:30,295 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV10 - 1 :: getting dv GV9 2022-07-01 16:02:30,295 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV3 - 0 :: getting dv GV9 2022-07-01 16:02:30,296 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV5 - 5 :: getting dv GV9 2022-07-01 16:02:30,296 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV6 - 60 :: getting dv GV9 2022-07-01 16:02:30,297 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV7 - 1 :: getting dv GV9 2022-07-01 16:02:30,297 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV8 - 1 :: getting dv GV9 2022-07-01 16:02:30,297 Thread-6 udi_interface.node DEBUG node:getDriver: harmonyctrl:HarmonyHub Controller GV9 - 2 :: getting dv GV9 2022-07-01 16:02:30,298 Thread-6 udi_interface DEBUG Controller:handler_start: GV9=2 activity_method=2 2022-07-01 16:02:30,468 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message notices 2022-07-01 16:02:30,469 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING notices 2022-07-01 16:02:30,470 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2022-07-01 16:02:30,494 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2022-07-01 16:02:30,586 MQTT udi_interface.interface INFO interface:_message: Successfully set harmonyctrl :: GV3 to 0 UOM 25 2022-07-01 16:02:30,625 MQTT udi_interface.interface INFO interface:_message: Successfully set harmonyctrl :: GV7 to 6 UOM 25 2022-07-01 16:02:30,668 MQTT udi_interface.interface INFO interface:_message: Successfully set harmonyctrl :: GV7 to 4 UOM 25 2022-07-01 16:02:30,773 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2022-07-01 16:02:30,812 MQTT udi_interface.interface INFO interface:_message: Successfully set harmonyctrl :: GV7 to 5 UOM 25 2022-07-01 16:02:30,862 MQTT udi_interface.interface INFO interface:_message: Successfully set harmonyctrl :: GV7 to 1 UOM 25 2022-07-01 16:02:31,723 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2022-07-01 16:03:22,864 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-07-01 16:03:22,866 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-07-01 16:03:22,867 Thread-8 udi_interface DEBUG Controller:shortPoll: ... 2022-07-01 16:04:22,870 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-07-01 16:04:22,872 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-07-01 16:04:22,873 Thread-9 udi_interface DEBUG Controller:shortPoll: ... 2022-07-01 16:05:22,876 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-07-01 16:05:22,878 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-07-01 16:05:22,879 Thread-10 udi_interface DEBUG Controller:shortPoll: ... 2022-07-01 16:06:22,904 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-07-01 16:06:22,905 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-07-01 16:06:22,907 Thread-11 udi_interface DEBUG Controller:shortPoll: ... 2022-07-01 16:07:22,853 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2022-07-01 16:07:22,855 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2022-07-01 16:07:22,856 Thread-12 udi_interface DEBUG Controller:longPoll: ... 2022-07-01 16:07:22,857 Thread-12 udi_interface INFO Controller:heartbeat: hb=0 2022-07-01 16:07:22,858 Thread-12 udi_interface.interface DEBUG interface:send: PUBLISHING {'command': [{'address': 'harmonyctrl', 'cmd': 'DON'}]} 2022-07-01 16:07:22,903 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2022-07-01 16:07:22,905 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2022-07-01 16:07:22,906 Thread-13 udi_interface DEBUG Controller:shortPoll: ... 2022-07-01 16:07:22,945 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message command
  4. I see the readme that "Currently, Roomba 980, Roomba 960, Roomba 890, and Roomba 690." Any plans to add s9+ model and Braava jet m6? Thank you -Dane
