ktierney662
  1. Thank you for the help gentlemen! Not leaving the "FROM" blank was causing the issues. On my home unit, I just have one word in that line and works fine. On the rental unit I had the email address in there as well.
  2. Thanks for the reply Gedd the issue is mail not getting out, the test message, and the programs I have set up will send out the "default" message, but when I try to send a custom message, nothing happens. I've set this ISY up the same way as the one in my home that sends messages fine. I've attached a new full error log, as well as a warning I received as well. ISY Error Log.v5.3.4__Wed 2022.10.12 12.05.44 PM.txt
  3. Thanks Mr. Bill... Updated to 5.3.4, issue persists... New error log attached.
  4. Hello All, first off thanks for all the help offer the years I’ve found just reading all the posts here. I’ve been lurking for a long time learning, and fixing my own issues. But I’m finally stumped enough to reach out for help. I have a system at my home, and another at a rental home.(both 994i with PLM’s) Rental home unit was recently reset to factory defaults, then installed as new. Everything works fine except the only messages I can get the rental unit to send is default messages, will not send a custom message (as the unit in my home will) I duplicated the settings I have in the working home unit, but still cannot get a custom message out. I did get a “MAIL SERVER” [Write Failed] message this morning? Home ISY is on version 5.0.16C Rental ISY is on 5.3.0 Removed the old Z-Wave board out of rental ISY since I have no Z Wave there, and I believe I need a PLUS board now. Any suggestions would be much appreciated Error Log attached ISY Error Log.v5.3.0__Mon 2022.10.10 12.36.06 PM.txt
