JForma
Everything posted by JForma
  1. I checked the output of the Red wire and I was only getting the negative voltage -60 volts AC 60hz. No change to the output signal when changing speeds. I took out the Triac (Q10) from the board and tested it and it seems to be fine. I think that the problem is the through holes for Q10 are not connected to the anything on the backside of the board. the connections are on the top where the package is. I am going to re-solder and check it. The caps were charging when I connected it to check continuity. Ill let you know. ;)
