RMichael
  1. Thanks for the update.
  2. I have a Tesla Model S and the Tesla EV Plug-in has stopped working. I read you other post and 1.) reloaded the refresh token, 2.) deleted and reinstalled the Plug-in and 3.) reloaded the refresh token and restarted, but the PLug-in did not connect to Tesla. Any thoughts or recommendations? Rod
  3. Installing a second Plug-in worked perfect! This is a great Plug-in. Thanks again for your help.
  4. Thanks for the quick response! I'll Install another instance of the plug-in and see what happens. I'll get back to you with results.
  5. I recently purchased a Ratgdo device for one of my Lift Master GDOs. I configured the dives, installed it and it worked flawlessly! Based on that experience, I purchased 4 additional units for my remaining GDOs. After configuring the new nodes, I attempted to install the first of the additional Ratgdo devices, but it was not discovered. I decided to reinstall the Plug-in and try again, but that did not work. In fact, the original device was no longer recognized by the Ratgdo Plug-in. I now get this message when I try to discover devices A Discover or device command was attempted with no MQTT connection established. Wait for the plugin to establish a connection to the MQTT broker before attempting Discover or device commands. Waited overnight, but nothing changed. Please advise on potential solutions. I have attached the log file for your reference. ratgdo_6-16-2024_85600_AM.zip
  6. First, thanks for developing this plug-in! I have 8 Hunter-Douglas shades, 5 of which are controlled by a Gen2 Hub and 3 that are controlled by a Gen 3 hub. After installing and configuring the the Plug-in (Config attached), the Plug-in was able to discover and control the Gen 3 shades, but did not find the Gen 2 Hub or Shades. I may be doing somethin wrong in the configuration. I have also attached the log to give you more detail on the experience. Thanks in advance for your help. Rod HunterDouglas_6-16-2024_84619_AM.zip
  7. Same Error. What is your timing for the MQTT stand alone version.
  8. RMichael replied to RMichael's topic in Hue
    Philips recommends no more than 50 Hue lamps on a single Hue Bridge. I currently have over 80 installed. From the Hue Bridge Buying Guide: https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.philips-hue.com%2Fen-us%2Fproducts%2Fsmart-light-accessories%2Fhue-bridge-buying-guide&data=05%7C01%7C%7Ce1367232a0f148d6dac508dbd1d00b09%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C638334463701965382%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=m%2FZKHqIQYCjx5uQG3DfN0SrJUXNLe560F3cpjY5g4VY%3D&reserved=0 I tend to agree that the best approach might be to run multiple instances of the node server. Do you have any experience with the IP address changing in the Hue Bridge and the pg3 no longer being able to communicate with it? Any known fix. Thanks for responding!
  9. RMichael posted a topic in Hue
    What is the best way to have multiple Hue hubs when using ex-kings Hue Polyglot? Should I 1.) Run multiple instances of the Hue Polyglot. 2.) Run multiple Hue Hubs through a single Polyglot instant. 3.) Recommendation door others. Please provide direction on how to proceed and instruction on how to do it. Thanks
  10. After updating to V.5.7.0 I had two issues occur. 1.) All Programs were disabled. *not that big of a deal. had to go through and enable each program individually. Is there a way to "Enable All"? If not, might want to consider. 2.) The node server store display the message "Getting installable Node Server list from Polyglot Store. Standby ...". THe list is never generated. Any Ideas?
  11. Moved my ISY over to Polisy and attempted to implement eMail notifications. I entered the information for my Outlook accounts and created a group and then saved. When I clicked on test, no appears to happen. I don't get any errors or receive a Test eMail. I have observed that a minute or so after clicking the Test button I am prompted to login and then told that the ISY has restarted and to open another session. Any Ideas?
