satwar
  1. >Except for one time, when everything run perfectly. I did nothing but it worked. Sadly it has only ran once . any ideas ?
  2. I think this discussion has drifted from my original question of what the pop-up error message I/O Error: ProxyDevice could mean. I have looked pretty hard in wiki isy994 to no avail. Perhaps it's time to move on to a new topic.
  3. oops, i upgraded to 5.3.4 and it all went well except my schlage lock is not well. Is there a fix or is it toast. I wasn't really using it for remote operation. sorry for asking so much, but there's a lot of info Yes i stopped virus software but no improvement.
  4. Thank you for the info. I swapped the 5 volt power supply that came with an earlier ISY model. No results My trouble is with step 3. Step 3 is a minefield. First finding the correct firmware. I have ISY firmware 5.0.16C and Z-Wave at firmware 4.55.00. There is a lot of problems with Z-Wave series 200 and I'm not sure what series I'm in.
  5. Sorry for the delay but i'm having problems getting on line with this forum. I don't what the leds are supposed to be, but my ISY has a single solid blue light labelled POWER Yes I cleared the java cache. The documentation says I don't have to format a new SDcard.
  6. sorry but i lost my post, will try again later. basically the problem is that the isy launcher boots up but gets me lots of "I/OError:ProxyDevices" followed by rebooting. I tried a new 16 GB and 32 GB sdcard but the isy launcher doesn't run at all. The original SD card was 4 GB
  7. I noticed that the ISY finder finds My Lighting with the old 4GB card installed, but the ISY finder finds ISY with the new 16GB card installed
  8. Yes there is a lot of info there, but I'm still stuck. I cleaned the contacts in both microSD cards. The performance of the 4GB card was better but far from perfect. At least the isy994 loads I tried a 16GB card and isy994 won't load at all
  9. Thank you, but I will try changitng the card. What is the optimum size of the card. I'm currently using 4gb
  10. My Isy994 system has served me well, especially the many people who have provided me technical support over the years. I noticed, however that I'm getting a high frequency of errors with the red text message "I/OError:ProxyDevices", followed whay appears to be a reboot. I desperately need some troubleshooting advice. Thanks in advance
  11. well it's been a tough go but it seems the io linc 2450 is not compatible without going through more equipment. I saw that the bright white SET led flashes on the up and on the way down, about several seconds after the door starts moving. I'm not sure why the SET light flashes differently than yesterday but the liftmaster opener is difficult to ensure the wiring is well connected to the wiring receptacle. Thanks for all your help.
  12. Wow you're keeping me busy. (1) Both 2450 's are revision 1.5 as printed on the label on the back of the device. Isy says both are version 0.36 (2) The green SENSOR led is ON when the door is travelling (not making contact with floor magnet) and is OFF when the door is closed (making contact with floor magnet) (3) When the door is travelling (not CLOSED) and the door reaches the fully OPEN position, the green SENSOR led turns OFF and there is one bright white flash of the SET led (4) Both 2450's are set the same, Momentary C mode @ 2 seconds (5) I haven't asked Liftmaster about the compatibility with dry closure pulses because I don't know that much about electronics. I read somewhere that the Liftmaster 8365W was obsolete. so there may be some hope that the old electronics design was still being used.
  13. One thing that is confusing me is that the insteon 2450 for Left door does not produce a flash of very white light upon closing door, but the Right door does not.
  14. Yes there is a bright white pulse of light on the led labelled SET on the insteon 2450. The SENSOR light also shows up for a brief time as a bright green light. I'll have to get some more details
  15. Yes, thank you, the Sensor seems to be toggling ON/OFF in sync with the door operation OPEN/CLOSED as desired. Now here comes the tricky part. The COM and NO terminals on the insteon 2450 do connect to the door oontrols. This is where I get confuised
