MrMike
Everything posted by MrMike
  1. What's the workaround? I'm having the same issue.
  2. Hi, I'm having an impossible time getting Polisy to recognize a Schlage FE599 ZWave lock. It paired properly on my ISY ZWave 500 hardware. I've tried doing factory resets on the FE599 (successfully) but when I attempt to add it under IoX/Polisy, I get absolutely nothing. Any troubleshooting thoughts. I've tried 15-20 times, thus far. I've done the bulk of this with the Polisy 2ft to 3inches from the lock. Thanks, Michael
  3. Hi, is there any way to surface the Temperature, motion, and Battery info into a status? The info appears present and accurate in the nodes. It would be great to use Temperature as a status. Thanks, Michael
  4. Thanks very much. Yep, the pkg install squared it away!
  5. Thanks Bob, and Panda, I'm gathering this is the issue? 12/29/2022, 14:51:20 [pg3] error: [YoLink(3)] :: STDERR: from yoLink_init_V3 import YoLinkInitPAC File "/var/polyglot/pg3/ns/000db95335fc_3/yoLink_init_V3.py", line 5, in <module> import psutil ModuleNotFoundError: No module named 'psutil'
  6. Hi, I am trying to install the YoLink NS (PG3 v 3.1.16). I have added the key and secret, but cannot get the node to start. It starts and then immediately disconnects. I am also unable to pull a log, as I get an error that the log is not found.
