terrygb2000
  1. OK Michel, Some progress, I found the router IP address using at&t web page help guides I found I had to enable Telnet in windows 7 which enabled me to access ISY26-HOME-AUTO, I gave it a new static IP address. Downloaded and installed latest Java using the link. Opened My Lighting admin console, Help > about > gave me the name and IP address and v.2.7.5 information. I then set the Time zone ( 1hour off daylight savings or not) exited then came back in to find a ! in front of the network and MY lighting blocks in the main tab. Also File is the only tab on the top it would allow me to highlight. So it's late, I will try again tomorrow and re-boot everything Thanks Terry
  2. Michel, Windows 7 does not appear to have My Lighting as a Network option. The router is At&t Uverse wireless !! When I power up the ISY the RX/TX come on solid red then the Mem flashes for a second then all leds go off
  3. Michel, Sorry for the delay I was at work. I am now in front of my computer. You asked: Would you be kind enough to let me know what you mean by "nothing"? Can you access the Admin Console? Can you login? And, if so, what's your ISYs firmware version? Yes I can open an Admin console window,. When I go File/logon "Nothing" As to the firmware version, I do not know, I purchased the ISY26 as a refurbished latest firmware a couple of weeks ago, no paperwork came with it. The 2 lights under the ethernet cable are green with the right hand one flashing a heartbeat. the 4 on the top "nothing"
  4. I have an unreliable X10 system, so I took the plunge and purchased a ISY-26 (as a start, I hope to upgrade to a ISY-99i later) and a Dual Band PLM 2413S ( I was told the 2412s was obsolete). I have a new Dell vostro i7 running windows 7. When I plug the 2413s using serial cable into the ISY26 then that into my network - nothing. I have green lights on both devices. The only other Insteon device I have at present is a RemoteLinc, I was hoping to use this to control the current X10 devices. Where do I start?? Please help
