GRoehrborn
Everything posted by GRoehrborn
  1. GRoehrborn replied to GRoehrborn's topic in ISY994
    Thanks MrBill. Everything matches. I think I am going to restart. I feel that something must be corrupt internally. Is there any steps on the most effective way to start over?
  2. GRoehrborn replied to GRoehrborn's topic in ISY994
    Thanks I have tried both New Insteon Device and Link Management. For motion sensor I did - Link a Sensor and selected Motion sensor. Same result. I have installed new batteries in motion sensors and tried the factory resetting.
  3. GRoehrborn replied to GRoehrborn's topic in ISY994
    Yes I can toggle flagpole light from the admin console. The ISY will not connect to both my front motion sensor or back motion sensor. After upgrading I had to reinstall of the devices to make them communicate with the new PLM. The motion sensors were working until I upgraded the firmware. I removed the back motion sensor and then tried to reinstall and I get cannot communicate to Insteon Engine. I cannot connect to either motion sensors or garage door control and status module. When I click on my network should the PLM be displayed? I currently to not see it.
  4. GRoehrborn replied to GRoehrborn's topic in ISY994
    Thanks I do have the addresses entered correctly. The ISY is seeing the PLM because other devices and programs are working. I also did clear the java cache and downloaded the IoX Launcher. Why is there a 7th digit in address? Flag Pole has a #1 and Motion sensor has a #2? Do I just need to un-install Java and Iox. Then restart the ISY and enter all of the devices again? Thanks
  5. GRoehrborn posted a topic in ISY994
    Hi My system was running find until a storm last summer. It took out my PLM. I have finally found a replacement PLM. However after installation everything went a little sideways. I ended up updating firmware and UI to v5.3.4. I had to reinstall all of my devices because they would have there six digit address but with a 7th digit (#1) behind them. Both of my wireless motion sensors and garage door relay won't connect I get an error message Cannot Determine Insteon Engine. After rebooting I do get communication from garage door sensor that is is open, but I cannot see it on admin console or connect to to it. Also, many programs have a status of "Out of memory". At this point I just want to restart and start from ground zero. I have an ISY 994i. What firmware should I be running? Thanks for any help.
