Eric
  1. Geddy; It's a new eisy. Firmware IoX v.5.7.0 UI also I0X v.5.7.0 (eisy (5226) Dennis, I just did the restore. Still the same issue. The nutty thing to remember is that if everything is on, and I use the wall switch in the Den, the den turns off and the ceiling fan remains on as it should. But if I use the admin console, or amazon echo to turn off the den, the ceiling fan also goes off, which it should not. Seems to me like there is something wrong with the 'Den' scene....I just can't see anything wrong.
  2. All, I have a strange behavior happening and I've got an idea about it, but I don't want to get too aggressive before the gallery here get's a chance at it. In my den, I have a switchlink wall dimmer. It has no load directly connected because the wiring goes to an outlet that is not in the right place. I also have a lamp dimmer module plugged into an always on outlet where I want to put my lamp. I have them both in a scene called Den, with the wall switch in control. Nothing else is supposed to be in that scene. It works as expected. When I turn on the switchlink wall plate, the LEDs on it climb up as expected, and the lamp also brightens to the expected level. In another room, I have an On / Off switchlink in the wall, with a ceiling fan connected as the load. No scene involved, turn on the switchlink LEDs go on and the fan operates. Turn the wall switch off and the LEDs go down and the fan turns off. Now for the strange part. If I use the ISY Admin Console, or if I use Amazon Echo, the 'Den' scene controls the Den lamp module, the LEDs on the wall plate as before AND the Ceiling fan! I don't see any programming done wrong in in the admin console, but I must have something wrong in the ISY, because I only see the problem when using the ISY control of the Den scene, or Amazon Echo using the Den scene. I'm thinking my next move might be to delete the Den scene and see if anything changes and then rebuild it and see if it stops controlling the Ceiling fan. Any thoughts on what I should be looking for ? Eric
  3. Resolved by support. Several issues, but all good now. Any idea how to put the admin console on a desktop shortcut in Windows 11 instead of just in the taskbar ?
  4. Almost made it with going to the EISY from 944. I think I'm just not getting to the internet from the new eisy. Everything in the house seems to work, and I can operate things from the admin console in the eisy. Unfortunately, Amazon Echo is not working, and when I try to migrate the portal licenses I can see both the old 944 and the new eisy. I go to 944 and choose that and say 'migrate from' and then select the eisy, and choose migrate to. I get the warning that this can't be reversed, but when I say OK, I get a message that the EISY can't be found. I presume that the EISY can't reach the UD server to migrate the license ? How can I be sure that the EISY is on the internet ? I might have to make changes in my router....I'm using DHCP on my network, but how do I make sure the EISY is set up to go out ?
  5. All; I'm trying to choose my upgrade path. Right now I have an ISY 994 with a serial PLM. I could get the new eisy and also get a new PLM with an IP connection....but then I have to get both of them working before I have my system back. The other idea is to get the EISY and the serial adapter and stay with the old PLM. But I know they have a limited life, so then I'd probably replace the PLM in short order anyway. Any thoughts on the right path ? Eric
  6. Understood. I think I also want to understand the new product a bit better. I thought it was just a modern ISY, but with a phone app to do the setup, I am wondering if there is still something like the admin console from a PC that I will use to create and maintain my programs. I'll do a little study. At least I have a backup from today to start from. Eric
  7. Mr. Bill; Thanks for the directions. I'm sure you saved me hours puzzling it out! I now have a new backup and the admin console pinned to my taskbar. I'm going to start down the path of replacing my ISY before it becomes unsupported. Any experience with converting from the ISY to the eisy | home ? I think all I need is the eisy and in my case the serial PLM kit... then I should be good to go for as long as the eisy has support. That should be a good long time. Eric
  8. Mr. Bill; Thanks. I have to run out for a little while, but I will try it tonight. I was almost certain that I needed to work with Java first. I had just un installed what I had to begin a new try. The one I had was Java SE Development Kit 19.0.2 which I was pretty sure was wrong....but I needed to know what was likely to work. I'll try again shorty using Java 8. Get it from the Oracle site ? We'll see how it goes. Eric
  9. All; I just got a new Lenovo Laptop that came with Windows 11. I want to install the admin console so I can back up my ISY 994i 256 so that I can then upgrade to the eisy home that will replace the 994i soon. Unfortunately, I can't get the Admin Console to install to the new PC. I have a ticket in with Universal Devices, but so far we are not having success. I suspect I need a different version of java on the new machine, and after trying with the most recent version available from Oracle, I'm stuck. I get a brief window that opens and closes when i use start.jnlp, but it does not install anything to the desktop so I can log into the ISY. When I log in to the ISY at it's interface, I get the basic console, but when clicking on the Admin Console, I just get the white page that asks me to leave it open. but no login page. ISY is Model Platform ISY-C-994 Version 5.3.4 Build Timestamp 2021-07-07-14:46:02 Any thoughts ? I have a backup from 2021, so I suppose I could just try ordering the eisy and a new power line modem and try to do the upgrade in the blind with an old backup, but if I can't event connect to my old controller with the new PC, I am reluctant to start sinking more cash into this ecosystem, which has been so good to me in the past. Eric Washington, DC
  10. Well, a little progress, but I think this KPL is likely toast (or at least the software for button C) I did the complete removal of the KPL and re added it to the system. This time id came up as KeypadLink Dimmer 6 Buttons v.36, so at least it reported the software version. I added everything back in slowly and all was well until Button C. Now, first press of Button C, All the LEDs on the KPL go off and there is a strange sound, the outlet turns on. A couple seconds later, the LEDs come back on in whatever pattern they were in but Button C is off even though the outlet is on. Next on push turns on the LED for button C, and the outlet remains on. Third push the outlet and the button go off. I have an identical setup on Button B with a different outlet and all is well. I think the simplest thing is to get a new KPL. In any case, it will put a spare on the shelf if it turns out this is my software, but I'm betting on a defective KPL. Thanks for the help. I'm going to re read the cookbook, but I think I'm doing it right. One further question. Is it allowed to have a button on another KPL control 2 scenes to toggle on and off ? If so, does the Button on the other KPL track only one of the scenes or is there some kind of logic used ? Eric
  11. Well, a little progress, but I think this KPL is likely toast (or at least the software for button C) I did the complete removal of the KPL and re added it to the system. This time id came up as KeypadLink Dimmer 6 Buttons v.36, so at least it reported the software version. I added everything back in slowly and all was well until Button C. Now, first press of Button C, All the LEDs on the KPL go off and there is a strange sound, the outlet turns on. A couple seconds later, the LEDs come back on in whatever pattern they were in but Button C is off even though the outlet is on. Next on push turns on the LED for button C, and the outlet remains on. Third push the outlet and the button go off. I have an identical setup on Button B with a different outlet and all is well. I think the simplest thing is to get a new KPL. In any case, it will put a spare on the shelf if it turns out this is my software, but I'm betting on a defective KPL. Thanks for the help. I'm going to re read the cookbook, but I think I'm doing it right. One further question. Is it allowed to have a button on another KPL control 2 scenes to toggle on and off ? If so, does the Button on the other KPL track only one of the scenes or is there some kind of logic used ? Eric
  12. I see the buttons toggle mode in the bottom of the KPL page. All of the buttons are set for toggle. I will go through and remove the KPL from all scenes it appears in. All the buttons as well as the base KPL. Then I will remove the KPL itself from the ISY and then do a reset on the KPL..and then bring everything back as a new entry. I do have another KPL with vacant buttons so I can move the test to that, but it's going to be giving me some exercise since it's downstairs. I'm hoping that at least at the end of this I can determine if I need to buy a new KPL. Eric
  13. Quite maddening. All seems OK as I build up the scene. As soon as I add Button C on the Terrace, the problem manifests again. lilyoyo1, I don't know how check toggle mode beyond looking at the Admin screen, and there I don't see anything unusual. Any thoughts on how to check that what I see in the admin console is what's in the KPL. I'm going to wipe the KPL again, but if something stray is coming in from ISY, I don't know how to see it. MrBill, When you say, get the module deleted from all scenes, do you mean the KPL or the outlet needs to be deleted ? I did delete Button C from every scene and then tried adding it back but the problem persists. Perhaps I'm not resetting, deleting and adding back in the right order. Seems quite nuts so far. Everything is OK from the admin console until I add the button C back in. Also, I made the outlet a controller. I'm not interested in pressing the button on the outlet itself, but I would like the button on the KPL to track what the outlet is doing. If the KPL button and the outlet are both controllers in the scene, should that make everything track ? Eric
  14. OK, we are closing in on something. I first just was careful to do the reset as pointed out by Mr. Bill, and after restoration the same problem was there. I then did another reset following lilyoyo1's instructions. After the reset but before the restoration from the ISY, Button C was working normally with a single push for on and then a single push for off...normal toggle state. After restoration from the ISY, it was first push turns on the outlet, backlight stayed off. Second push outlet stayed on, backlight came on. Third push, backlight and outlet went off. So we went off the rails when I did the restore from the ISY. I am considering deleting the scene from ISY and seeing what happens, and then rebuilding it. Any thoughts ? Eric
  15. Might be onto something here. Looking in the admin console, the Terrace KPL is: (2486D) KeypadLinc Dimmer v.00 All of my other KPLs have a software number after the v. Maybe it's just going to need to be replaced with a new one ? Eric
