kcrossley
  1. Looking to save some $$s. LOL
  2. Yes, the Dakota has some very nice features, but no night mode. However, a night mode can be programmed through the ISY, which is how I have mine setup.
  3. I'm already using an IR-3000 with an Insteon 5010E (EZSNSRF) and I was going to add another sensor. Perhaps I should just stick with an IR-3000. http://www.smarthome.com/smartenit-ezsnsrf-dakota-alert-wireless-sensor-receiver.html
  4. Aside from price, what's the difference between these two devices? Is one any better than the other? http://www.smarthome.com/dakota-alert-ir-3000-3000-series-wireless-ir-motion-sensor.html http://www.smarthome.com/insteon-2842-222-wireless-motion-sensor.html
  5. I'm having similar problems with the same kind of Insteon Device. I tried LeeG's suggestion of using Event Viweer and changing to level 3 and this is what I received. The 2475S is inside an exterior flood light. What does this indicate? Sat 06/23/2012 02:27:44 AM : ---- Initializing the linked devices ---- Sat 06/23/2012 02:27:44 AM : ---- All Linked Devices are now initialized ---- Sat 06/23/2012 02:27:44 AM : ---- Add remaining devices ---- Sat 06/23/2012 02:27:44 AM : [ 8 84 70 1] Removing all links Sat 06/23/2012 02:27:44 AM : [8 84 70 1 ] Querying engine version Sat 06/23/2012 02:27:44 AM : [iNST-ACK ] 02 62 08.84.70 0F 0D 00 06 (00) Sat 06/23/2012 02:27:53 AM : [iNST-ACK ] 02 62 08.84.70 0F 0D 00 06 (00) Sat 06/23/2012 02:28:02 AM : [iNST-ACK ] 02 62 08.84.70 0F 0D 00 06 (00) Sat 06/23/2012 02:28:06 AM : [8 84 70 1 ] Failed getting engine version. Reverting to i1. Sat 06/23/2012 02:28:06 AM : [8 84 70 1 ] Using engine version i1 Sat 06/23/2012 02:28:06 AM : [iNST-ACK ] 02 62 08.84.70 0F 28 0F 06 SET-MSB(0F) Sat 06/23/2012 02:28:15 AM : [iNST-ACK ] 02 62 08.84.70 0F 28 0F 06 SET-MSB(0F) Sat 06/23/2012 02:28:24 AM : [iNST-ACK ] 02 62 08.84.70 0F 28 0F 06 SET-MSB(0F) Sat 06/23/2012 02:28:28 AM : [ 8 84 70 1] ** Not added ** Remove Device Links failed Sat 06/23/2012 02:28:28 AM : ---- All Remaining Device Added ----
  6. I can confirm that these settings do indeed work with iCloud and Verizon text messaging: SMTP Server: smtp.mail.me.com SMTP Port: 587 User ID: your-user-id@me.com Password: (leave this blank) From: your-user-id@me.com Timeout: 1000 Use TLC: Unchecked
  7. Hey Michel. Good to hear from you. You are correct. The switch is an 8-button KeypadLinc Dimmer,but the floodlights are connected to Smarthome In-LineLincs (Non-Dimming). What is an ELK? Any insight on to why this happened? Do you think I should reset the ISY-26? Thanks, Kelly
  8. By the way the floodlights indicated in the log are fluorescent and can only be on or off (0 or 100%), but the log shows 88% which isn't even possible.
  9. Not sure what I'm looking at, but I did find the log of when the anomaly happened: Here are the details: 0 null Tue 06/14/2011 06:41:13 AM System Start 0 pool.nt Tue 06/14/2011 06:41:18 AM System -60001 Scene:My Lighting Status 0% Tue 06/14/2011 06:41:18 AM System Log Fireplace Lamp-Right Status 0% Tue 06/14/2011 06:41:18 AM System Log Fireplace Lamp-Right Status 0% Tue 06/14/2011 06:41:20 AM System Log Fireplace Lamp-Right On Level 100% Tue 06/14/2011 06:41:20 AM System Log Fireplace Lamp-Right Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:20 AM System Log Floodlight - Left Status 0% Tue 06/14/2011 06:41:20 AM System Log Floodlight - Left Status 0% Tue 06/14/2011 06:41:20 AM System Log Floodlight - Left On Level 100% Tue 06/14/2011 06:41:20 AM System Log Floodlight - Left Ramp Rate 2.0 Sec Tue 06/14/2011 06:41:20 AM System Log Floodlight - Rear Status 0% Tue 06/14/2011 06:41:20 AM System Log Floodlight - Rear Status 0% Tue 06/14/2011 06:41:21 AM System Log Floodlight - Rear On Level 100% Tue 06/14/2011 06:41:21 AM System Log Floodlight - Rear Ramp Rate 0.1 Sec Tue 06/14/2011 06:41:21 AM System Log Floodlight - Right Status 0% Tue 06/14/2011 06:41:21 AM System Log Floodlight - Right Status 88% Tue 06/14/2011 06:41:22 AM System Log Floodlight - Right On Level 100% Tue 06/14/2011 06:41:22 AM System Log Floodlight - Right Ramp Rate 0.1 Sec Tue 06/14/2011 06:41:22 AM System Log Foyer 1-Front Porch Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 1-Front Porch Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 1-Front Porch On Level 45% Tue 06/14/2011 06:41:22 AM System Log Foyer 1-Front Porch Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:22 AM System Log Foyer 2-Living Room Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 3-Lamp Post Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 4-Family Room Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 5-Garage Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 6-Morning Room Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 7-Outside Status 0% Tue 06/14/2011 06:41:22 AM System Log Foyer 8-Inside Status 0% Tue 06/14/2011 06:41:22 AM System Log MR 1 - Floor Lamp Status 0% Tue 06/14/2011 06:41:22 AM System Log MR 1 - Floor Lamp Status 0% Tue 06/14/2011 06:41:23 AM System Log MR 1 - Floor Lamp On Level 100% Tue 06/14/2011 06:41:23 AM System Log MR 1 - Floor Lamp Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:23 AM System Log MR 3 - Left Flood Status 0% Tue 06/14/2011 06:41:23 AM System Log MR 4 - Right Flood Status 0% Tue 06/14/2011 06:41:23 AM System Log MR 5 - Rear Flood Status 100% Tue 06/14/2011 06:41:23 AM System Log MR 6 - Deck Lights Status 0% Tue 06/14/2011 06:41:23 AM System Log Recessed Porch Lights Status 0% Tue 06/14/2011 06:41:23 AM System Log Recessed Porch Lights Status 45% Tue 06/14/2011 06:41:24 AM System Log Recessed Porch Lights On Level 45% Tue 06/14/2011 06:41:24 AM System Log Recessed Porch Lights Ramp Rate 2.0 Sec Tue 06/14/2011 06:41:24 AM System Log Chandelier - Hall Switch Status 0% Tue 06/14/2011 06:41:24 AM System Log Chandelier - Hall Switch Status 50% Tue 06/14/2011 06:41:24 AM System Log Chandelier - Hall Switch On Level 50% Tue 06/14/2011 06:41:24 AM System Log Chandelier - Hall Switch Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:24 AM System Log Chandelier - Foyer Switch Status 0% Tue 06/14/2011 06:41:24 AM System Log Chandelier - Foyer Switch Status 50% Tue 06/14/2011 06:41:25 AM System Log Chandelier - Foyer Switch On Level 50% Tue 06/14/2011 06:41:25 AM System Log Chandelier - Foyer Switch Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:25 AM System Log Morning Room Fan Light Status 0% Tue 06/14/2011 06:41:25 AM System Log Morning Room Fan Light Status 45% Tue 06/14/2011 06:41:25 AM System Log Morning Room Fan Light On Level 45% Tue 06/14/2011 06:41:25 AM System Log Morning Room Fan Light Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:25 AM System Log Morning Room Lights Status 0% Tue 06/14/2011 06:41:25 AM System Log Morning Room Lights Status 45% Tue 06/14/2011 06:41:26 AM System Log Morning Room Lights On Level 45% Tue 06/14/2011 06:41:26 AM System Log Morning Room Lights Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:26 AM System Log Fireplace Lamp-Left Status 0% Tue 06/14/2011 06:41:26 AM System Log Fireplace Lamp-Left Status 0% Tue 06/14/2011 06:41:26 AM System Log Fireplace Lamp-Left On Level 100% Tue 06/14/2011 06:41:26 AM System Log Fireplace Lamp-Left Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:26 AM System Log Family Room Fan Light Status 0% Tue 06/14/2011 06:41:26 AM System Log Family Room Fan Light Status 0% Tue 06/14/2011 06:41:27 AM System Log Family Room Fan Light On Level 30% Tue 06/14/2011 06:41:27 AM System Log Family Room Fan Light Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:27 AM System Log Billiard Room Status 0% Tue 06/14/2011 06:41:27 AM System Log Billiard Room Status 50% Tue 06/14/2011 06:41:27 AM System Log Billiard Room On Level 50% Tue 06/14/2011 06:41:27 AM System Log Billiard Room Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:27 AM System Log Garage Lights-Exterior Status 0% Tue 06/14/2011 06:41:27 AM System Log Garage Lights-Exterior Status 0% Tue 06/14/2011 06:41:28 AM System Log Garage Lights-Exterior On Level 45% Tue 06/14/2011 06:41:28 AM System Log Garage Lights-Exterior Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:28 AM System Log Family Room-Right Status 0% Tue 06/14/2011 06:41:28 AM System Log Family Room-Right Status 0% Tue 06/14/2011 06:41:28 AM System Log Family Room-Right On Level 100% Tue 06/14/2011 06:41:28 AM System Log Family Room-Right Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:28 AM System Log Family Room-Left Status 0% Tue 06/14/2011 06:41:28 AM System Log Family Room-Left Status 0% Tue 06/14/2011 06:41:29 AM System Log Family Room-Left On Level 100% Tue 06/14/2011 06:41:29 AM System Log Family Room-Left Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:29 AM System Log Living Room Lamp Status 0% Tue 06/14/2011 06:41:29 AM System Log Living Room Lamp Status 0% Tue 06/14/2011 06:41:29 AM System Log Living Room Lamp On Level 100% Tue 06/14/2011 06:41:29 AM System Log Living Room Lamp Ramp Rate 4.5 Sec Tue 06/14/2011 06:41:29 AM System Log Scene:Outside Lights Off 0 Tue 06/14/2011 06:41:30 AM Program Log Scene:Inside Lights Off 0 Tue 06/14/2011 06:41:30 AM Program Log Scene:Chandelier-Foyer Off 0 Tue 06/14/2011 06:41:30 AM Program Log Chandelier - Hall Switch Status 0% Tue 06/14/2011 06:41:31 AM System Log Chandelier - Foyer Switch Status 0% Tue 06/14/2011 06:41:31 AM System Log Scene:My Lighting Fast Off Tue 06/14/2011 08:28:32 AM Web Log
  10. kcrossley posted a topic in ISY994
    Apparently, last night my ISY-26 went crazy and decided to turn on a whole bunch of lights randomly. We discovered it this morning. This has never happened before. It's about 4-years old. Could it be reaching it's end-of-life? Are there any diagnostics I can run to see if it's functioning properly. Thanks, Kelly
  11. I'm having similar issues. Did you purchase your TED 5000 direct from the manufacturer or through a distributor?
  12. I'm having similar issues. Did you purchase your TED 5000 direct from the manufacturer or through a distributor?
  13. So before you changed the dip switch you weren't able to use it in a program?
  14. The Dakota EZSnsRF receiver shows up, as do the KPL and LampLinc, but the IR-3000 does not. I have not been able to successfully use the EZSnsRF as a control in a program, but I'm not a programmer, so I could have something coded wrong. Thanks for your help.
  15. I am able to make the Dakota work in a scene, but not with a program. Since the scene doesn't understand time of day, that method is very wasteful "energy wise".
