axmill8
Everything posted by axmill8
  1. I tried the factory reset the PLM, I then un-plugged it and the ISY994i, I then plugged in the PLM and subsequently powered and connected the ISY using a CAT5 cable. PLM Info/Status reports Not Connected. Restoring the PLM also fails. It appears this PLM is not working properly.
  2. Ticket submitted before these posts was not helpful and points to final ISY goodbye. I guess returning the PLM is my next recourse.
  3. Thank you for the replies. Yes, I have tried the Restore PLM from the file menu in the Control Panel. And when I check the PLM status in the Diagnostics area I get PLM Not Connected (see screenshot). I tried replacing the CAT5 cable and that did not change the situation. Opening a ticket, since ISY994i is no longer supported, do I need to pay for support first before submitting the ticket?
  4. After over 12 years of operation, my ISY994i system stopped working apparently because the PLM 2412s died. Status of PLM showed unable to communicate. I purchased a new PLM 2413s and have not been able to get the ISY994i and PLM to talk to each other. My ISY994i appears to be working, it still controls my one Zwave light. No insteon devices connect. Additionally, I am able to use the UDI IoX launcher to start up and open the Control Panel. I have turned off the ISY99i, plugged in the PLM, restarted the ISY994i and I get no communication between the two devices. From the control panel I've tried to reset the PLM and I get either a "Failed to Reset PLM" error message and sometimes a "Subscriber Connect Failure [0]" plus the Failed to Reset PLM. If I try to delete the PLM, it won't do it because it is not connected. I tried doing the reset PLM while having the PLM in Linking Mode (pressing LED button 4 seconds until it starts beeping) and running the Reset PLM. Nothing works. Any ideas?
  5. I gather from reading on this forum that the current ISY-99i firmware is v.2.7.14 RC1. I have firmware v. 2.7.0 and to use a Weather bug module it says I need to be at least v2.7.7. Do I need to do an intermediate version upgrade say to 2.7.7 before going to 2.7.14 RC1 or can I upgrade the firmware from v. 2.7.0 to v. 2.7.14 RC1 directly? Is there some intermediate "full release" I should be using, or is v. 2.7.14 RC1 ready for prime time? Thanks. axmill8
