Grimgoth
  1. I belive so. How to I validate?
  2. I have paid for one node server, gotten another on trial and another that was free. None of them have asked me to install. After digging aroud a bit, I came across these logs and it looks like something is wrong with my database. This was an import from an older ISY to the Eisy and I have made sure my versions are IoX v5.6.0 and PG3 v3.1.26. I am seeing the following in the logs: 5/12/2023, 20:00:06 [pg3] info: Successful login by admin 5/12/2023, 20:00:06 [pg3] info: Updating mqtt frontend password to jwt token 5/12/2023, 20:00:06 [pg3] info: call_udx: Making reqeust to socket for /rest/pg3.frontendpw.ns 5/12/2023, 20:00:06 [pg3] info: call_udx: /rest/pg3.frontendpw.ns on socket happened. 5/12/2023, 20:00:06 [pg3] info: call_udx: /rest/pg3.auth.ns on close happened. 5/12/2023, 20:00:06 [pg3] info: call_udx: /rest/pg3.frontendpw.ns on finish happened. 5/12/2023, 20:00:06 [pg3] info: call_udx: incoming chunk {"status":"success"} 5/12/2023, 20:00:06 [pg3] info: call_udx: /rest/pg3.frontendpw.ns returns {"status":"success"} 5/12/2023, 20:00:06 [pg3] info: call_udx: /rest/pg3.frontendpw.ns on close happened. 5/12/2023, 20:00:06 [pg3] info: Getting push notification API token 5/12/2023, 20:00:11 [pg3] info: Starting log stream for pg3frontend_pSeBT :: /var/polyglot/pg3/logs/pg3-current.log 5/12/2023, 20:00:27 [pg3] info: Calling reinstall.reInstallAll.... 5/12/2023, 20:00:27 [pg3] error: Getting all node servers from database 5/12/2023, 20:00:27 [pg3] info: Back from reinstall.reInstallAll.... 5/12/2023, 20:02:06 [pg3] info: Verifying node servers are installed on IoX correctly 5/12/2023, 20:02:06 [pg3] warn: verifyNodeServers (00:21:b9:02:62:bc) :: IoX has no node servers installed. 5/12/2023, 20:04:56 [pg3] info: Getting push notification API token 5/12/2023, 20:07:06 [pg3] info: Verifying node servers are installed on IoX correctly 5/12/2023, 20:07:06 [pg3] warn: verifyNodeServers (00:21:b9:02:62:bc) :: IoX has no node servers installed. 5/12/2023, 20:10:15 [pg3] info: Getting push notification API token Any help would be appreciated.
