AMann
  1. Will do. Thanks
  2. Actually, installing from the above location worked - I didn't have to clear the java cache. Thank you!!!
  3. I did what you suggested. No change. Still blank admin UI. Firmware is 5.5.9. No idea about UI version since the screen is blank and there is only a File menu (see screenshot). No Help-->About menu to even find out.
  4. finder did not see it automatically. I manually added it with the port (two separate rows - one for 8080/http and one for 8443/https) just to test both - no difference. I couldn't have gotten as far as I did with the blank screen without the correct URL
  5. Just received my new eisy to replace a ISY-994i. I was able to set it up (so I thought) using the QR code and received no errors, but now when I add the new device in the ISY finder and open the admin console, it is completely empty/blank. Any advice/help? Thanks.
