hchucky
Everything posted by hchucky
  1. The ISY-26 was flaky for quite some time so it it possible there was some corruption there. I will do a factory reset on the new unit and start from scratch. Thanks, HC
  2. I just upgraded to an ISY994i Pro from an ISY26. I restored my config from the ISY26 and one of the devices shows up under My Lighting with a corrupt name "Back YaR$ ,o/$ Lights". This device does not show up on the left hand tree so I can not select it to rename it. The device is a 2876S Icon On/Off Switch v00. I haven't looked but it is likely that this was corrupted in the ISY26 as well. How do I correct the name on this device? Thanks, HC
  3. Thanks for the posting. I set that up and it works perfect. HC
  4. I currently have an X10 motion sensor that I use to turn on a mudroom and closet light. This works well as is but I would like to enhance it so the lights stay on as long as there is motion. In other words every time motion is detected I would like to reset the timer to 10 min. Currently the lights get turned off after a 10 min wait but if you are still in the room you have to hit the switch or move around a bit to turn them back on. Thanks, HC
  5. What PLM does the ISY require? I currently have a 2414u (v2.1) could that be used with a DB9-USB cable or will I be required to purchase a 2412S. Thanks, HC
