jzgersten
  1. Has anyone designed or figured out a way to have a device listen in a room a la a baby monitor, and then have lights flash in another room to alert a parent? Is there an insteon sensor that I just haven't found online yet? Thanks in advance.
  2. Gentleman, So I restored family-main. An retried program to no avail.. I then restored the PLM and ran the following test I opened event viewer as you suggested and then pressed family - rear (15.0B.46)(dimmer), family - main (14.A2.4E)(dimmer), and then family - front (15.12.7D)(on/off), on and then off in the same order. The following was the event log: Fri 12/03/2010 01:21:36 AM : [iNST-SRX ] 02 50 15.12.7D 00.00.01 CB 11 00 LTONRR (00) Fri 12/03/2010 01:21:36 AM : [standard-Group][15.12.7D-->Group=1] Max Hops=3, Hops Left=2 Fri 12/03/2010 01:21:36 AM : [ 15 12 7D 1] DON 0 Fri 12/03/2010 01:21:36 AM : [ 15 12 7D 1] ST 255 Fri 12/03/2010 01:21:36 AM : [iNST-SRX ] 02 50 15.12.7D 0F.9D.D1 41 11 01 LTONRR (01) Fri 12/03/2010 01:21:36 AM : [standard-Cleanup][15.12.7D-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Fri 12/03/2010 01:21:39 AM : [iNST-ACK ] 02 62 00.00.4C CF 13 00 06 LTOFFRR(00) Fri 12/03/2010 01:21:48 AM : [iNST-SRX ] 02 50 15.12.7D 00.00.01 CB 13 00 LTOFFRR(00) Fri 12/03/2010 01:21:48 AM : [standard-Group][15.12.7D-->Group=1] Max Hops=3, Hops Left=2 Fri 12/03/2010 01:21:48 AM : [ 15 12 7D 1] DOF 0 Fri 12/03/2010 01:21:48 AM : [ 15 12 7D 1] ST 0 Fri 12/03/2010 01:21:49 AM : [iNST-SRX ] 02 50 15.12.7D 0F.9D.D1 41 13 01 LTOFFRR(01) Fri 12/03/2010 01:21:49 AM : [standard-Cleanup][15.12.7D-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Fri 12/03/2010 01:21:51 AM : [iNST-ACK ] 02 62 00.00.4C CF 13 00 06 LTOFFRR(00) Fri 12/03/2010 01:22:36 AM : [iNST-SRX ] 02 50 14.06.B0 0F.9D.D1 07 6E 44 (44) Fri 12/03/2010 01:22:36 AM : [standard-Direct][14.06.B0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Fri 12/03/2010 01:22:36 AM : [ 14 6 B0 1] ST 136 Back to the family - front 15.12.7D...When upgrading recently to 2.8.6, I lost all but 19 links in my PLM (out of like 529). I did restore then as well, but this issue has plagued me for some time...
  3. Gentleman, I opened event viewer as you suggested and then pressed family - rear (15.0B.46)(dimmer), family - main (14.A2.4E)(dimmer), and then family - front (15.12.7D)(on/off), on and then off in the same order. The following was the event log: Fri 12/03/2010 12:21:38 AM : [iNST-SRX ] 02 50 14.06.B0 0F.9D.D1 07 6E 44 (44) Fri 12/03/2010 12:21:38 AM : [standard-Direct][14.06.B0-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Fri 12/03/2010 12:21:38 AM : [ 14 6 B0 1] ST 136 Fri 12/03/2010 12:21:46 AM : [iNST-SRX ] 02 50 15.12.7D 00.00.01 CB 11 00 LTONRR (00) Fri 12/03/2010 12:21:46 AM : [standard-Group][15.12.7D-->Group=1] Max Hops=3, Hops Left=2 Fri 12/03/2010 12:21:46 AM : [ 15 12 7D 1] DON 0 Fri 12/03/2010 12:21:46 AM : [ 15 12 7D 1] ST 255 Fri 12/03/2010 12:21:46 AM : [iNST-SRX ] 02 50 15.12.7D 0F.9D.D1 41 11 01 LTONRR (01) Fri 12/03/2010 12:21:46 AM : [standard-Cleanup][15.12.7D-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Fri 12/03/2010 12:21:49 AM : [iNST-SRX ] 02 50 15.12.7D 00.00.01 CB 13 00 LTOFFRR(00) Fri 12/03/2010 12:21:49 AM : [standard-Group][15.12.7D-->Group=1] Max Hops=3, Hops Left=2 Fri 12/03/2010 12:21:49 AM : [ 15 12 7D 1] DOF 0 Fri 12/03/2010 12:21:49 AM : [iNST-SRX ] 02 50 15.12.7D 0F.9D.D1 41 13 01 LTOFFRR(01) Fri 12/03/2010 12:21:49 AM : [standard-Cleanup][15.12.7D-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Fri 12/03/2010 12:21:49 AM : [ 15 12 7D 1] ST 0 Fri 12/03/2010 12:21:49 AM : [iNST-ACK ] 02 62 00.00.4C CF 13 00 06 LTOFFRR(00) Fri 12/03/2010 12:21:52 AM : [iNST-ACK ] 02 62 00.00.4C CF 13 00 06 LTOFFRR(00) It seems that only the front on/off is registering 15.12.7D...However, what to do next is beyond me...lol...thanks for your help.
  4. My Family - LED scene only has the one KPL button i in it. None of the devices are in it...I have tried your program and it still seems to be dependent on the use of the Icon on/off switch, the dimmers have no effect...strange
  5. Checked the switches none are controllers in any way. Tried the single program, and it's the same response?!?!?
  6. So here is an interesting one…I have my Family room controlled by 3 switches, front, main, and rear. These in turn are controlled by a button on a KPL. I hit the KPL, and all lights r on, and KPL is lit. If KPL is pressed again, all lights off and KPL is off. What I’m trying to do is have the KPL off if any one or more of the other 3 switches is off, and have the KPL on ONLY when ALL three switches are ON. The rear and main are Icon dimmers, and the front is an Icon switch. What’s happening is that the program works only when the Icon Switch (front) is turned on or off…pressing either of the dimmer/rear/main switches does not activate the program successfully. Here is the programming If Status 'Family - Main' is Off Or Status 'Family - Front' is Off Or Status 'Family - Rear' is Off Then Wait 3 seconds Set Scene 'Family - LED' Off Else - No Actions - (To add one, press 'Action') If Status 'Family - Front' is not Off And Status 'Family - Main' is not Off And Status 'Family - Rear' is not Off Then Wait 3 seconds Set Scene 'Family - LED' On Else - No Actions - (To add one, press 'Action') Obviously I have a scene called Family-LED with only the KPL in it. Any suggestions would be appreciated.
  7. jzgersten replied to jzgersten's topic in ISY994
    Internal jumper is not present. And the triggerlinc is only in one scene, I do not use the "secondary." Thus, open door, light goes on. close door nothing happens. that way light is on when enter bathroom, but must manually turn off light when exit. Now I understand when I open the door to exit another command is sent to turn light on, but i would think a manual turn off would be sufficient...Rand said these cleanups, which I guess are sent 3x? are what's turning the light back on...need to suspend the cleanups for this to work....but dont know how...
  8. jzgersten replied to jzgersten's topic in ISY994
    Thanks for the lesson Rand!! Now is there anything I can do to fix it for me...I had it working once before no problem, so there must be a fix...
  9. jzgersten replied to jzgersten's topic in ISY994
    Yes not pressing the switch means aok...how do i deal with cleanups...not familiar with that term...Thanks Rand!
  10. jzgersten posted a topic in ISY994
    I have a TriggerLincs attached to the door of each of two bathrooms. When the door opens lights go on. Close the door, do your business light is still on. Open the door turn off light manually, and uhoh, the light goes back on...as if the ISY is still sending an on command. Both locales are scene controlled as opposed to program because I want the lights on quick. Does anyone have any idea why this might be happening? Thanks.
  11. OK, so on a lark I tried this scenario on another KPL that I have and it worked flawlessly...so the problem appears to be localized on one KPL...I have another KPL on order so I will swap that one out and hopefully no problems..we'll see...thanks to all for your help, much appreciated.
  12. I cannot turn off the LED at all , ever eithe manually or via software
  13. Ok so here goes: Main Scene - "Garage KPL - Master" Controller - 'Garage KPL - Master' Button B on a six button KPL .v36 rev 54 (non-toggle - On) Responders - 1 3way - L1, L2 1 4way - H1,H2,H3 1 Single MBCE 1 Single MBOC Secondary Scene - 'Garage to Master Bed LED' = "Garage KPL - Master" ONLY Button B on a six button KPL .v36 rev 54 If Control 'Garage KPL - Master' is switched On Then Wait 10 seconds Set Scene 'Garage to Master Bed LED' Off Else - No Actions - (To add one, press 'Action') [/code] All I want is the LED to turn off in the sub button B,,,Thanks The software reports it is off, but the physical button is still on.
  14. With all of your help (separate scene and program turning scene/sub button off) I have the sub button reporting that it is off in three places the device itself, the scene where it is the controller, and the scene where it is the responder...unfortunately the physical button still shines like a beacon...what am i doing wrong?
  15. Could I just adjust the back-light to a zero level, and if so can you recommend an easy way to do that?
