buckeyebez
  1. Thank you so much for your efforts in this. When Awake, i'm receiveing data from my tesla just fine. However, it doesn't seem to be receiving data when I send a command from my eISY to the car. Is the data stream one way, or might have i configured something incorrectly?
  2. Thank you for your efforts - they are greatly appreciated.
  3. Thank you for your efforts and for what your are doing.
  4. thanks so much for the information, greatly appreciated
  5. after a fresh reset, it seems to be much improved. I hypothesize that the memory cap was probably the solution to the problem. I appreciate your support!
  6. Thank you for your response. My version was 5.7.0, so I have updated to 5.7.1 I have tried clearing the Java Cache along with the new start.jnlp file. just prior I have now adjusted the memory cap to -Xmx1024m and will re-clear the cache and try a new start file. I am running windows 10 and the native firewall.
  7. I am a long time user of 994izw with zwave (coming up to 10 years in 2024) and recently migrated to an eISY. I am having problems with the speed of the interface in the programming mode(programming tab in the administrative console). It appears to be linked to my zwave devices. I have 7 individual zwave devices that seem to be causing the problem. I removed all of my zwave devices and it seemed to restore to normal. I reset my zwave module, then readded my devices and readded them to their respective programs. Now (and before), when I click on the programming tab, it will often not load the programming tab at all (the page appears blank with no programs, even though i know the programs are there because they run normally), and when it seldomly does, any work in that tab is painfully slow. I never had this problem with my 994izw, and have not added any additional or different devices since I made the upgrade. I'm open to any suggestions or troubleshooting steps recommended. Thank you! ISY.pdf
