buckeyebez
Everything posted by buckeyebez
  1. Thank you so much for your efforts in this. When Awake, i'm receiveing data from my tesla just fine. However, it doesn't seem to be receiving data when I send a command from my eISY to the car. Is the data stream one way, or might have i configured something incorrectly?
  2. Thank you for your efforts - they are greatly appreciated.
  3. Thank you for your efforts and for what your are doing.
  4. thanks so much for the information, greatly appreciated
  5. after a fresh reset, it seems to be much improved. I hypothesize that the memory cap was probably the solution to the problem. I appreciate your support!
  6. Thank you for your response. My version was 5.7.0, so I have updated to 5.7.1 I have tried clearing the Java Cache along with the new start.jnlp file. just prior I have now adjusted the memory cap to -Xmx1024m and will re-clear the cache and try a new start file. I am running windows 10 and the native firewall.
  7. I am a long time user of 994izw with zwave (coming up to 10 years in 2024) and recently migrated to an eISY. I am having problems with the speed of the interface in the programming mode(programming tab in the administrative console). It appears to be linked to my zwave devices. I have 7 individual zwave devices that seem to be causing the problem. I removed all of my zwave devices and it seemed to restore to normal. I reset my zwave module, then readded my devices and readded them to their respective programs. Now (and before), when I click on the programming tab, it will often not load the programming tab at all (the page appears blank with no programs, even though i know the programs are there because they run normally), and when it seldomly does, any work in that tab is painfully slow. I never had this problem with my 994izw, and have not added any additional or different devices since I made the upgrade. I'm open to any suggestions or troubleshooting steps recommended. Thank you! ISY.pdf
