Arnaud42
  1. Hi, I try to change the power to medium and low, but it does not change anything unfortunately, event when only the 5GHz is down.
  2. Hello, I personally have only one wifi router, which broadcast in 2.4 and 5GHz. My computer detect 3 other wifi networks around, with pretty weak signals. I change my wifi in 5GHz to a different SSID than 2.4GHz, to be sure. I tried both 20MHz and 40Mhz channel width and tried almost all channels without any success (13 in total) There is also a transmitter power I let to high.
  3. Hi, I have some LIFX Color 1000 since 6 years and since I changed of internet provider few months ago, it doesn't stay connected anymore. Yet I use my own WIFI router, TP-Link EAP245 which was working well so far and I tried numerous WIFI settings without any success. They stay connected about 5 minutes only. They all start to dysfunction at the same time, so I don't think it's due to the bulbs. I also tried to use them in another home and then it start to work perfectly again and don't disconnect. So there is definitely something wrong in my home. Did you already face the same issue ? Or do you have any idea of the issue ? Thanks in advance, Arnaud
