Joe2120
  1. Joe2120 replied to Joe2120's topic in ISY994
    Actually it’s more likely they turn off. When troubleshooting in Admin Console I often get communication errors with micro switches. the transformers are required to control low voltage I’ll look into the filters
  2. Joe2120 joined the community
  3. Joe2120 posted a topic in ISY994
    Getting frustrated with trying to get my lighting to work consistently. Sometimes it does, sometimes it doesn't. ISY 994i/IR Pro (1110) / OpenADR(21010) / Z-Wave (21100) UD Admin Console v5.3.0 Serial PLM Dual Band SwitchLinc Dimmer v.45 Micro On/Off Switch Module Micro Dimmer Switch Module (bought because On/Off wasn't avail at the time) These items are controlled as follows 1) Dual Band Switch controls outdoor string lights plugged into outlet 2) Micro switches control 2 separate sets of low voltage lighting (each on own transformer) I have simple programs created 1) Turn string lights and one set of low voltage lighting on from sunset to midnight (Dual Band switch should also do this same function manually) 2) Turn other set of low voltage lighting on from sunset to sunrise The issue is the communication to the low voltage lighting using the micro switches is very intermittent. The programs work occasionally but I can manually turn individual lights (under devices) with no issues. I also have the MobiLinc Pro app and have the same success controlling individual light. The dual band switch always work on the string lights because they're plugged directly into the outlet they're controlling. The micro switches are inconsistent. Any ideas?
