BobT
  1. Wonderful Javi! Thank you for tackling this issue.
  2. Hi, When I press the scene member's calculator icon while the scene is opened in UD Mobile, as expected, I get the "Ignore this scene member's status when making the Estimated Status calculation. This will not remove the node from the scene" notification. BUT after closing the Device Dashboard (even after clearing the UD Mobile App's cache and restarting), my selection to ignore the scene member does-not-stick. I'm using Android. In the past, this function worked just fine. Does anyone have experience resolving this issue? Thank you. Bob
  3. UPDATE: Even though UD Administrative Console says Sunset is 4:07pm (see image), the program I have set to run at sunset DID indeed run at 5:07pm, very close to actual sunset (see the other image).
  4. Same here...my eisy reports correct DST time, but sunrise/sunset are reporting 1 hour earlier than actual. Reboot did not help.
  5. I am experiencing the same issue. I upgraded from ISY994 to EISY a few months ago. Before upgrading, the 3 Insteon Motion Sensor II 2844s I am using were reporting Battery Powered correctly along with a usable relative (but not accurate) Battery Level. After upgrading, Battery Powered usually reports "False", and Battery Level is rarely updated. It seems like the much faster EISY isn't waiting long enough for the MS II to complete its transmission of the data. Any advice is welcomed.
