Joshhall
Everything posted by Joshhall
  1. I wasn't verified on the website and could only get single codes. I got verified today and was able to get the code set. After pasting in the new codes and deleting older nodes created while testing, I was able to get it to work. Thank you for your help.
  2. I was able to install the plugin and I had a previous code I was using before but the Yamaha Receiver did not turn on. I set the plugin to: key: url value: http://192.168.0.241 key: Master RCVR value: function, code1, hexcode1, code2, hexcode2 "On","sendir,1:2,1,38000,1,1,342,168,23,20,23,61,23,61,23,61,23,61,23,61,23,61,23,20,23,61,23,20,23,20,23,20,23,20,23,20,23,20,23,61,23,20,23,61,23,61,23,61,23,61,23,61,23,61,23,20,23,61,23,20,23,20,23,20,23,20,23,20,23,20,23,61,23,20",,, I tried to follow the instructions provided and got: value: function: POWER ON code1: sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,21,21,64,21,64,21,64,21,21,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,64,21,21,21,1517,341,85,21,3655 hex code1: 0000 006d 0022 0002 0155 00aa 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 05ed 0155 0055 0015 0e47 code2: hex code2: The email I received was: code set: 1674 function: POWER OFF code1: sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,64,21,21,21,21,21,21,21,64,21,21,21,1517,341,85,21,3655 hex code1: 0000 006d 0022 0002 0155 00aa 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 05ed 0155 0055 0015 0e47 code2: hex code2: Has the format changed?
  3. I changed it to 255 and it worked. Thank you for your help.
  4. I am working on a laptop that is Windows 10 Home. I am trying to wake up a PC with Windows 10 Pro.
  5. I reset several things and am now able to see the device. I press the test button and see: 2024-08-25 14:35:35.050 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS command message {'address': '12345678', 'cmd': 'WOL', 'query': {}} from Polyglot 2024-08-25 14:35:35.050 Command udi_interface INFO wol:wakeOnLan: Sending magic WOL packet to 12:34:56:78:90 (Living PC) But with the correct MAC Address. But the computer still does not turn on. I press the test button in a Wake on LAN App on my tablet and the computer boots. I believe the PC is set up correctly and the log shows that it sent Wake On LAN. Is there anything else I need to set?
  6. I do not see a Wake on LAN Node. I tried Plugins -> Wake-on-LAN -> Add Node -> Wake-on-LAN which gave me a new window with Name, Node Address and Primary Node Address. What do I put in for these fields?
  7. I was able to add the key but how do I trigger it? I setup a program and selected Run Then to trigger the Wake On LAN 'Living PC', but it is still not working. I didn't see any instructions on how a program interacts with Polyglot.
  8. I didn't see that I had to scroll down pass collapse Configuration Help. I only saw the shortPoll and longPoll. Now, I see the key. Thank you.
  9. I saw that before and was able to login to Polyglot 3.x. I click Dashboard -> Wake-On-LAN(1) -> Nodes(0) It shows Nodes 0 How do I add a node?
  10. 1. It says that the Configuration -> Networking -> Wake On LAN page is not used at all and is no longer supported on eISY? 2. After looking at the information, I don't think we are talking about the same thing. I select Plugins -> Wake-On-LAN -> Add Node -> Wake-On-LAN: A window pops up: I See Name, Node Address and Primary Node Address. I don't see a Key anywhere. What do I type in for the fields? 3. This is a new eISY and I have not setup anything specific for the PolyGlot V3. Do I need to change any settings on Plugin -> Configure?
  11. I have a eISY and set it up to send an email to my phone as a SMS Message which was actually easier than I thought. However, the message that comes out is too long. I was able to create a custom format and reduce it some, however it is still too long: ************************************* FRM: 123456789012345-12345678-1234-1234-1234-123456789012-123456@mail.universal-devices.com SUBJ:Laundry Door Closed MSG:Laundry Door Closed ************************************* Is there a way to change the "FRM:" and remove the "FRM:", "SUBJ:" and "MSG:" from the text? Ideally Just: ************************************* Laundry Door Closed ************************************* I would also like the phone number I receive it from not to increment after each message. Currently every message comes from a different phone number.
  12. I recently purchased an eISY to replace my ISY-994 which is much faster and easier to work with. I would recommend allow the eISY to take Insteon addresses without a "." like FE3476. This is how I saved a list of devices and it is very annoying when I forget the dot and have to type the address all over again. Other than that I was able to get about 50 insteon devices to work again. I am trying to do Wake on Lan to wake up a PC when I turn on a Insteon switch. I went to Configuration -> Networking -> Wake On LAN Typed in the MAC Address. I tried the Test button which didn't work. I created a program to send a Wake on LAN if the Switch is switched On and Status is Off, but it doesn't work. I tried to Run Then on program and it still didn't work. I installed the Wake on LAN plugin and went to Plugin Configuration but I don't know what the User ID/Password/Base URL and Host Name should be. I downloaded an app on my tablet with the same mac address and it works. I looked in the Wiki and the Forums but didn't see any additional information. Oh, and do you know when the ZMatter usb dongle is going to be available? Or some other Zigbee and ZWave Dongle? I would like to get new devices but feel Insteon is being replaced.
  13. I was able to update to a newer version. Thank you for your help.
  14. I Currently have an ISY 994i/IR PRO with Firmware Insteon_UD994 v.5.3.3 UI Insteon_UD994 v.5.3.3 Product ISY 994i/IR PRO OpenADR Z-Wave Portal Integration It shows Internet Access Disabled but it connects to Alexa and allows me to control my lights. I could not find any options to update firmware, except for Manually update ISY which I am unable to do because I am unable to find any new versions available? Is the 3-7-21 the latest version or is there a location with newer Firmware versions?
