scholarwarrior
  1. Well, I have 85 switches so that's a lot of programs to write. Also, this has the same issue with lights on multiple scenes as below. The log file is a sort of solution but loading this in excel and then massaging the data so that I can compute on/off combos is time consuming, and the results have a lot of incorrect info because the log records switch actions, and lights on multiple scenes may be turned on by one switch and then turned off by another. So the script parsing the data would need to know the lights which respond to "all off" for instance.
  2. Is there a way to generate report on total on / off time as well as use during day/night, etc? Or some other way to get a sense of which lights are on most often?
  3. I'd like to download a csv or text list of all the devices listed in my "Network" section, including the device address, type and name. Is there a way to do this?
  4. So follow on question: there's a delay when I do this with an EISY program vs being part of the scene. Is there a way to eliminate the delay? It does not seem to be the "ramp" delay of the keypad. i.e. it behaves the same no matter what I set as "ramp rate" on the keypad. So I push on, light on keypad goes to on immedately, then there's an approximately .5 second delay and the green led at the bottom of the keypad flashes, and then the program executes the "scene on" command.
  5. Ok, sorry. "Control x is On" translates to "is switched on" Now it works. Thanks!
  6. Well, I don't know how to get the Admin Console to do 'Basement / BSMT Stair' is switched Off I only see "status is" Not sure what selections to use which would result in "is switched off" I have "sechedule" "condition" "action" and "comment" and none have "is switched off"
  7. I have several places where I want the "on" command to switch on only some of the lights, but the "off" command to switch off ALL the lights. EG I have a basement with a workroom and a playroom. I want the basement keypad "on" to turn on the playroom only, but when if I turn on the workroom light manually, I want the keypad "off" command to turn off the playroom AND workroom. I can't seem to get this to work with "scenes" I can get it to work if I add individual "workroom light 1 off" and "workroom light 2 off" in a program, but not if I create 2 scenes. "playroom" and "all basement" set the keypad to control playroom and write a program that says "keypad Status is Off then "set all basement off" Why does this not work?
  8. Yeah, to the extent I have any issues they’re related to some old x10 devices that are flakey which I plan to replace with Insteon. Home Assistant seems very solid. I’m running it in a VBox VM in Windows and it allows me to integrate eisy with Nest and various tvs and stereo and ONVIF cameras and to control it all with Siri. Still working to bring the onvif cams into apple home…
  9. FWIW, I've decided to use Apple HomeKit / Siri for UI. I installed Home Assistant and bridged to HomeKit, but this works pretty well (though still new) and the UI in Apple Home is very simple and customizable so family can use.
  10. Yes, that works. Thanks. Now I'd like this same favorite icon to show the status of the scenes it controls. e.g. I have scene1 and scene2. program says if scene1 is on or scene2 is on then set scene1 off, set scene2 off else, set scene1 on; set scene2 on. Now I want this program to show the state (scene1 or scene2). Do I use a variable for this? How do I link the variable to the favorite icon so that it shows the variable state? Thanks again for your help!!
  11. I want a program to only run when I tap it's icon on the favorites menu. How do I set this up? Do I need a variable? Thanks for the help...
  12. Last on this: I had happened to have one of these lying around: https://www.x10.com/products/xpnr?_pos=4&_sid=41e7767a8&_ss=r I plugged it in-line with the fixture. Problem gone.
  13. Ok, when I disconnect that LED module everything works. the PLM gets all the X10 commands. The light in question is one of these: https://www.amazon.com/dp/B0D7Q1Z2RJ Any ideas on how to stop the interference? Also why is the interference affecting the PLM, but not the X10 lights or wifi controller? [edit] the same circuit has several other LED light modules and those being on do not cause any interference.
  14. The one switch is an Insteon 2477D. Resetting the switch made no difference. That switch controls LED recessed modules, but there is one LED module on that switch that I don't have anywhere else in the home. I'll try disconnecting that module. [edit] To answer the other questions: when that switch is on, the viewer doesn't show X10 commands (either on or off).
