PaulB
  1. Follow-up question.... will users of the ISY944 also have ongoing access to the ISY cloud portal once the interface for the EISY goes migrates from Java based to HTML?
  2. Thanks for the replies. As long as the current Java interface will continue to work, it looks like for my situation, there is no urgent need to upgrade to the EISY.
  3. Once the current Java interface has been replaced by the windows interface, what happens to ISY944 users?
  4. Just got my system back up and running. Thanks to the admin for suggesting that I re-boot my ISY. Once I did that, the system came back on line and I was able to re-link my devices in Google Home. Appreciate the help, and being back in business!
  5. When I log into my.iso.io I still do not get a green dot next to my device. When I select the ISY WEB Access option, I get a pop-up box saying "ISY is not online". For those of you that are back up and running, are any of you using an ISY994i or are you on the newer IESY? Also, I am located in Toronto Canada - not sure if that makes a difference.
