Ray95xxx
  1. I recently updated my Mac to java 4.8.1. Now the macOS or Safari won't let me run either start.jnlp or admin.jnlp (for security reasons). The only options are: a) do nothing or b) move the applets to the trash. I've rebooted the system, checked my java setting and security settings in the system setting, to no avail. The UD Mobile app continues to work and I can access the EISY via the web based UI, but I need to java based admin counsel to check and edit some programs. Suggestions?
  2. Techman, Thanks for your suggestions. Unfortunately, Mac OS won't let me open the start.jnlp because it could not verify it free of malware?? On the other hand, clearing the java cache and power cycling the EISY did allow my original ISY Launcher to find my EISY. However only non-greyed out item in the File menu are Logon and Exit, so I can't restore the EISY from backups. Suggestions?
  3. Bladerunner, I believe I have the same situation. Tried to follow all the Migration from Polisy instructions. The new EISY r2 was initially accessible from the Admin Console, but is now essentially dead. I can see that the Eisy is wirelessly connected to my network, and the Web Portal shows both the Polisy (which is powered off) and the EISY, but when I click Select Tools: ISY Web Access, it reports ISY is not online. Could you forward me Michael's instruction? Untitled.pdf
  4. ISY Error Log.v5.9.1__Sat 2025.06.14 08.48.14 AM.txt
  5. My Z-Wave devices recently stopped responding to programs run on my POLISY Pro. I power cycled the device and ran Upgrade Packages and rebooted the POLISY to no avail. Suggestions welcome... ISY Log.v5.9.1__Fri 2025.06.13 02.52.07 PM.txt
