DHemrick02
Everything posted by DHemrick02
  1. Also, I have noticed that if I restart the plugin, sometimes it will cause the values to update but sometimes not.
  2. I have a Flair setup with 4 pucks and 8 vents. All in all, it works really well when I set it to Auto mode. However, I wanted more control over it and integrated it into my Polisy system using the Flair plugin. I'm able to control it just like I want, but the issue that I am having is that the Flair plugin does not seem to be reading the temperature from the pucks correctly. For example, the Flair app will show the "Serenity Room" at 64.6 F which is accurate. However, the Flair plugin shows the Serenity Room at 62.6. The room is not being used and should be set to 64. This doesn't seem that bad, except I had an incident where someone was sleeping in a room and the Flair plugin thought the room was 62 degrees, opened the vent while the heat was running, and it made the room get up to 78 during the middle of the night. They awoke drenched in sweat. The issue is that I am not sure where the Flair plugin is getting the puck temperatures because they are not matching what is actually being reported by the pucks nor what is being shown in the Flair app. I looked into the logs and it is saying "no change in value" even when the room temperature changes according to the Flair app. This is happening for all of my pucks. I have my polling time set to be fairly frequent, but the logs still show no change. Here is one example: Anyone familiar with the Flair plugin can help? I've attached my logs for reference. Flair_1-20-2025_83504_PM.zip
