Error when adding Kasa
They are HS200 which is an hs220 but just a switch not a dimmer. They seem to be working now or at least allowing on /off and showing me status. All of a sudden it started showing up. Now if I can get my home assistant to expose them to homebridge that would be great but I cant seem to find which domain they are under.
Yea I added them in kasa App. I updated to the beta version of the kasa plugin in PG3 thenit saw all the devices and they are in the ISY but it just says connected. no ability to turn it on or off or anything. no info about it nothing.
I have a bunch of Insteon devices runnign in EISY fine. I added the Kasa plugin in polyglot UI and i couldnt add any of the devices. Then I added the beta version and now it at least sees my 4 HS200 switches. They are in ISY admin as well. They seem to just be kasa controllers tho and Can not be turned off or on. However when I click on the folder I added them to ( which it added the whole kasa controller to not just an individual device ) It knows which are on and off and that is accurate. I cant add them to any programs or anything like that. What am I doing wrong?
So I guess I need to enable the ISY portal which I wasnt using so i did that and was able to et the plugin running and a node set up. But I cant seem to add the kasa devices to it. Are there any tutotials for this? I cant seem to find one
I have a mostly insteon setup with a few zwave locks. I am trying to add a couple of Kasa light switches in an outbuilding that is on the same wifi network. I assumed i need to go to polyglot and add the kasa node server and pay the $30. But when I click activate free trial or purchase the license I get this error AxiosError: Request failed with status code 404
I think a java update broke my launcher
that did it. thanks
This is awesome. I was wondering if there was something like this.
I ended up updating my mac OS and rebooting then clearing java cache and redownloading the start.jnlp which seems to have fixed it. But it didnt make my iox launcher shortcut for me.
did that and it still gets stuck. redownload start.jnlp and it looks like its doing its thing but stuck at downloading application. Even though thats there the iox launcher gets added to the desktop. if I click that it looks like its gonna start with the UD logo on screen but just quits. Not sure where to go from here.
Did you still redownload the current java version or a specific build?
My mac popped up a java update and i clicked ok. Now when I click the launcher it shows the icon on the screen then quits right away. does not load the launcher finder window or anything. Anyone else experience this?
i3 Keypad ramp rate
Ok i did the factory reset and it still wont ramp on and off. I can dim the lights manually though so I guess I will submit a ticket to insteon
i3 Keypad ramp rate
yes i seem to have it set in ISY liek all the other switches but this one just clicks on and off I will be there today and try the factory reset first.
i3 Keypad ramp rate
Thanks for the info. what about how come I cant seem to get it to ramp rate on and off ?
i3 Keypad ramp rate
I have some i3 keypad and am able to make scenes and everything but some of them came from the factory where the bottom button is the actual controlled circuit. and some came with the top button as the circuit. Is there a way to change that? Also some of them seem to be able to ramp the lights on and off and some dont. I have set the mode of the main switch to dimmer and set the ramp rate. the same way I do everything else. Am I missing something?
toptierweb
Joined
Last visited
