dkh1020
Everything posted by dkh1020
  1. Hello, Here's the program - very basic...... • If • Status 'Living Room Thermostat - Main' < 73° (Setpoint) • Then • Set 'Test Module 1' On • Else Once I can get the ISY to recognize the change in setpoint, then I'll add some meaningfull code.
  2. Hello Rand, Thanks for the response. I've already done as you suggested and and can see the 4 nodes. As I said before, my ISY updates immediately with no need to query the thermostat. So, I would expect the program to kick off when the setpoint is adjusted beyond the threshold I've set. So far, no luck. Thanks ~Doug
  3. Hello all, I have a Venstar thermostat and an Insteon adapter (V2) that reports it's status to the ISY. My goal is to have the ISY recognize when someone sets the thermostat below a desired level and bump the temp back to a predetermined setting as well as have my Homeseer software announce a warning. I can set the venstar (at the thermoststat) to a speific temperature and the ISY sees the change immediately. However, if I have a program set up to trigger when the setpoint is below a certain temperature, it fails to kick off. If I adjust the temp via the admin console or via my I-phone, the program runs as expected. Also, if I query the thermostat via I-phone, the program runs fine. My code is super simple: If Status LR Thermostat <73 (Setpoint) Then "X" I just migrated from an Applied Digital Ocelot to the ISY so I'm getting my feet wet. Regardless, this should be a no brainer. I'm clearly missing something here. Any thoughts or suggestions would be much appreciated.
