ixlr8
  1. I have a program that I want to run in the morning, but not every morning and of course which day changes week to week. I presently have a program set up that IF keypad B is ON, then the program runs at a certain time. But at the moment, I have to manually press keypad B to turn it OFF. Is there a way to turn OFF keypad B via an ISY command rather than having to do it manually? Thank you
  2. They didn't have it when I ordered the caps for mine, so I didn't change that cap, I just replaced the others and the PLM is now working again.
  3. Before I saw your note, I did a "modem restore", exited out of the Admin console and then logged back into the Admin console, still had same error, couldn't communicate with KPL-B and KPL-B still showed red '!'. I just saw your note and went to run the test you requested and when I logged in, I did not get the communication with KPL-B error and all items the KPL-B now had 1011 in front of them. I then did a "restore device" and this time it spent a few minutes writing to the device and now all looks normal. !!?? To everybody who helped, thank you. I don't understand what happened, or why it is working, but at the moment everything looks to be running as it should. I did do one thing in follow up to the repair of the PLM that I probably shouldn't have, I connected the repaired PLM to the ISY with the ISY still running. I suspect I should have unplugged the ISY first.
  4. I have no battery operated devices in my system, no 1011 next to any device. Just red ! next to all KPL-B keys. To be clear, from my last post, I think all the sensors controlling the KPL-B key lights are associated with scene's and not programmed thru the PLM/ISY.
  5. Thanks for your input, here is what I have done and where things stand now. KPL- A; PLM had error it couldn't find it after my repair of the PLM. I did a "show device links table" for that KPL and it now appeared that the PLM could see it, but there was no communication to or from that KPL. Per your suggestion I did a "restore device" for KPL A, the system showed it was writing to the KPL- now it seems to function properly. Thank you KPL- B; Again PLM had error it couldn't find it, I tried doing the 'show device links table' for that KPL and it still shows that the PLM can't find it. I tried your suggestion to 'restore device' and unlike for KPL-A, nothing happened when I did that to KPL-B. I have sensors for doors open/closed and lights on/off in my shop, and the lights on KPL-B keys are working correctly to show the status of the sensors. So I am assuming that KPL-B is communicating some way. I have not rebooted the ISY controller or a modem restore yet. Jim
  6. My 2.5 year old 2413s died 2 weeks ago. No response to commands, programs not running, LED light out. I replace the caps per the list in this thread, LED now on, system taking commands from ISY now. Thank you to the folks who did the research on this issue and put together the parts list and supplier. But now when I startup the Admin Console it says that it can't connect with 2 of my 3 keypads. Is there something I should do to connect with them, I find it hard to believe that they would both go at the same time. One of them is only 4 months old. Would it hurt to do a modem restore even though I didn't replace the modem or do a factory reset? Thank you, Jim
  7. New one is a dimmer module, I thought the old one was as well. I just pulled the old one from the garbage and it was a relay module, guess it is time to start programming. Thanks
  8. Resurrecting an old thread as I have the same issue. I had a 6 button KPL that died, replaced it with a new one, I clicked on the old KPL and there was no option to replace it. My other 2 KPL's do show the option to be replaced, but not the dead one that I removed. Any suggestions on how to get the programs from my old KPL to the new one without lots of recoding?? Thanks
  9. ixlr8 replied to joe567890's topic in ISY994
    I called UDI, I was told a tech would call me back... nobody ever did. Did you download the file in that link or run it from the link? I tried to run it from the link and it didn't work.
  10. ixlr8 replied to joe567890's topic in ISY994
    I have the same issue, revoked certificate. I updated to the latest version of Java, cleared the cache... still the same issue, I can't access my console. Same expiration date, Aug-26, I am still running a ISY-99i, I have a 994 on order and I am trying to prepare my system for the upgrade. I tried the link Michel posted, but it told me that it couldn't find the ISY, it looked like it was looking for a 994.
  11. I have the same problem since I updated Java, for now I am stuck with the ISY99. I tried the above procedure, but I don't have an "edit site list" button when I go into the Java console Security tab. Running Win7, Java SE 7 U51 10.51.2.13, firmware 3.3.10, any further suggestions would be appreciated. EDIT- I checked the Java version, it shows Version 7 Update 15 (build 1.7.0_15-b03). I tried to update the software and it said the latest version was already installed did I want to install it again!!?? I did clear the cache, including applications, rebooted computer.. didn't help. EDIT2- I found I had to delete the old versions of Java before it would run the new version of Java. Once that was done I had the "edit site list" button and I made the changes and all is now working... thanks to all for the various posts I found via search.
  12. I already have the fixtures, I can post the ballast part numbers when I get home again in 2 weeks.
  13. The fixtures are 8' long with 4- 4' T8 bulbs each, they are wired in strings of 3 fixtures. So far my electrical loads are one small air compressor, one garage door opener and never more than 2 of the 4 stings of lights on at a time. 100 amp panel installed in shop, I need to replace the panel in the house before I can properly wire/feed the shop. I know that I am at the limit of my extension cord power supply to the shop.
  14. Interesting, I didn't know about these, but to do my whole shop with them would cost about $3100 for the bulbs!!! Filterlinks suddenly look cheap.
