fuzzersteve
  1. enabled DHCP.....could not connect except after the "not found" error... lucky my router config page shows connected device so i can get the IP turned off windows firewall on laptop, no change.....
  2. Michael, Thanks for the help.... Only using windows firewall on the system i am trying to access the ISY from.... I need to verify if it is still a ststic IP or not..... Steve
  3. For a minute there I thought we had it...but I got an error So, i used telnet and formatted the SDcard, (I think), then tried it again. This time around I clicked "Add" after clicking ok at the "not found" prompt and was able to add and log in there. I downloaded and then upgraded the firmware to the latest, but am still unable to log in thru "http://www.universal-devices.com/99i/". But I can access once I get the "not found" error... so this is where I'm at....
  4. I orginally set it up for static IP. i am able to determine the current IP address. I tried connecting thru the web browser, it prompted for usr/pwd. i connected, if I click "administrative console" it fails... I did clear JAVA and it still failed... Java Plug-in 1.6.0_21 Using JRE version 1.6.0_21-b07 Java HotSpot Client VM User home directory = C:\Users\Steve ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage o: trigger logging q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack x: clear classloader cache 0-5: set trace level to ---------------------------------------------------- load: class com.universaldevices.client.ui.UDClientApplet.class not found. java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source) at sun.plugin2.applet.Plugin2ClassLoader.loadClass0(Unknown Source) at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source) at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source) at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source) at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.io.IOException: open HTTP connection failed:http://192.168.1.3/com/universaldevices/client/ui/UDClientApplet/class.class at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source) at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source) at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) ... 9 more Exception: java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
  5. Specifically I'm talking about the ISY. I have performed a reset on the ISY several time, with the same result. As for losing communication...I mean when I click the ISY link...http://www.universal-devices.com/99i... the Administrative Console opens up, but it is a generic console. It does not prompt me to login. I've also tried to access it via IP, same result
  6. Brian...solid green pwr light Michael... whenever I factory reset I have to reprogram, I have done this at least 3 time since june. I only have 2 switches and am only turning them on and off with at dusk and dawn....
  7. I kep getting too busy, but I need help.... I keep losing "contact" with my ISY-991/pro. The only way I can restore communication is with a factory reset. I perform a factory reset, resetup my deviecs (only a few for now) and everything works for a few days then i lose communcation and automation stops.... Any ideas?
  8. fuzzersteve posted a topic in ISY994
    I installed 2 switchlinc relays, one for front porch, 1 for back porch. Linked them to my isy-99 and everything worked good...for 1 day Today, the sunset program did not work. I check the isy and there is an exclamation mark next to it and i cannot control it from the isy..says there is a communication error... the other switch is fine...could it be a bad switch?
  9. fuzzersteve posted a topic in ISY994
    Does the PLM have to be connected to the ISY if you have external power for the ISY? I have a 2412s plm....doesn't seem to work If it can be done, what model plm do I need? TIA steve
