matttotaro
Everything posted by matttotaro
  1. Michael, I can see the ISY's IP address from my router. I only tried telnet using port 126 with no success. I had not tried /99i until your suggestion. I use the Windows firewall. When I went to http://www.universal-devices.com/99i I was able to login. The first thing I did was try to upgrade. I was able to successfully create a backup, but the upgrade failed saying, "Invalid length". The Admin console seems to work fine otherwise. How should I proceed with the upgrade to 2.6.8? Matt
  2. I have been having a lot of problems with my ISY26 since I made some changes to my network. I switched my internet service to FiOS and I now have an Actiontec MI424/WR. Soon after, I replaced my laptop. I should say that I usually don't have to mess with my Insteon and ISY because my system has been stable for a long time - and even with the problems I am about to describe, my programs continue to run! My primary issue is that I cannot login to my ISY. I get to the Please Keep This Window Open screen, see the Java animation, but then Java throws an error. The error log is below. Java Plug-in 1.6.0_10-rc Using JRE version 1.6.0_10-rc Java HotSpot(TM) Client VM User home directory = C:\Documents and Settings\Parents ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage o: trigger logging q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack x: clear classloader cache 0-5: set trace level to ---------------------------------------------------- load: class com.universaldevices.client.ui.UDClientApplet.class not found. java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source) at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source) at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.io.IOException: open HTTP connection failed:http://192.168.1.11/com/universaldevices/client/ui/UDClientApplet/class.class at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source) at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source) at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) ... 7 more Exception: java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class I also cannot connect to the unit via telnet. I think my firmware was at 2.6.6 the last time I upgraded. I have tried power cycling the router, the ISY, and the PLM with no success. I have also tried connecting to the ISY through a different router with the same results. Can anyone point me in the right direction? Matt
  3. v2.4.6 I have seen references to version 2.5 beta. Where can I download it?
  4. Whenever I try to create a new schedule and save it, my entry disappears from the list. This is a new installation and I have never been able to successfully run a schedule. I choose New Schedule, set my options and hit OK. The record shows up in the list, but it is not active. I try to check tha active box but it doesn't work. When I save, it's gone. Am I missing something simple?
