JustinDR@cox.net
  1. I have a isy-99i that I am using to manage 12 Insteon dimmers / keypads. I recently have integrated control of the isy-99i from my Crestron processor using the REST interface and have run into a small snag. As of now, I can successfully control scenes that are programmed in the isy99, but I am not able to control a single dimmer. Here is the string I am sending for control of a scene. The scene ID that is displayed in the isy99 programming interface is 13714. This command seems to work fine for on and off. GET rest/nodes/13714/cmd/DON HTTP/1.1\x0D\x0AHost: 10.30.20.21\x0D\x0AAuthorization: Basic YWRtaW46YWRtaW4=\x0D\x0A\x0D\x0A What I can't figure out is how to control a single dimmer directly. My goal is to send a command to the dimmer (ex: on to 60%), then query the dimmer for it's status in order to provide level feedback to my touchpanels. I have tried the following strings to a dimmer with the address 14.98.DE, but none work... What am I missing? GET rest/nodes/14 98 DE/cmd/DON HTTP/1.1\x0D\x0AHost: 10.30.20.21\x0D\x0AAuthorization: Basic YWRtaW46YWRtaW4=\x0D\x0A\x0D\x0A GET rest/nodes/14 98 DE 1/cmd/DON HTTP/1.1\x0D\x0AHost: 10.30.20.21\x0D\x0AAuthorization: Basic YWRtaW46YWRtaW4=\x0D\x0A\x0D\x0A GET rest/nodes/14.98.DE/cmd/DON HTTP/1.1\x0D\x0AHost: 10.30.20.21\x0D\x0AAuthorization: Basic YWRtaW46YWRtaW4=\x0D\x0A\x0D\x0A Thanks in advance for any help you can provide.
  2. I am having an issue with the local on-level being changed by my lovely wife Example, I have a 6-button KPL in our baby's room. The top button is set for full on while one of the smaller buttons is set for a "night mode" which turns the lights on to a very dim level. What is happening is the lights are being turned on using the smaller button "night mode" and the bottom button is being pressed to turn the room off. When the bottom button is pressed, 9 times out of 10 the airgap switch is also being pressed which changes the top button (full-on) to the night mode level. Is there a way I can disable local levels being changed via the airgap switch? I do have an ISY99i I am using to manage the system if that makes a difference.
