gtrotter4
  1. Tim and Lee, Just wanted to thank you for your responses. I am very busy tonight but will definitely experiment with your suggestions when I have some more time. Thanks again! Extremely helpful.
  2. Thank you to all the authors and contributors of all the detailed threads. I've spent MANY hours reading the forums, wiki's, and how to's and you'd think by now I'd be capable of writing any script I needed- HA! I wish. I'm expanding my Insteon setup and need to learn ISY programming-- this is my first crack at writing programs. All of the state, body, condition programming is starting to make sense but I'm still very intimated. Goal: Turn On/Off coffee maker using the fast On/Off ToggleLinc relay controlling my fluorescent under cabinet lighting. I also don't want to change the status of the under cabinet light. I want to avoid any programming mistakes to prevent future headaches and unwanted surprises. Question: Are my 4 programs below the most efficient way to accomplish this? (they work but I don't think the light status is ideal) Do I need to create a state diagram with body's, condition's and all that jazz? The programs below get the job done but I'm not confident they are good. Please chime in with your thoughts as I'd like to add a similar program in the Master Bedroom where the Fan Relay Togglelinc controls the Master Lamps. First program: Coffee maker fast on. If Control 'Kitchen / Under Cabinets' is switched Fast On And Control 'Kitchen / Under Cabinets' is not switched Fast Off Then Set 'Kitchen / Coffee' On Else - No Actions - (To add one, press 'Action') Second program: Same as first program with cabinet light on. If -( | Control 'Kitchen / Under Cabinets' is switched Fast On | And Control 'Kitchen / Under Cabinets' is not switched Fast Off | And Status 'Kitchen / Under Cabinets' is Off -) Then Set 'Kitchen / Coffee' On Set 'Kitchen / Under Cabinets' Off Else - No Actions - (To add one, press 'Action') Third program: Coffee maker fast off If Control 'Kitchen / Under Cabinets' is switched Fast Off And Control 'Kitchen / Under Cabinets' is not switched Fast On Then Set 'Kitchen / Coffee' Off Else - No Actions - (To add one, press 'Action') Fourth program: Same as third program with status light on If -( | Control 'Kitchen / Under Cabinets' is switched Fast Off | And Control 'Kitchen / Under Cabinets' is not switched Fast On | And Status 'Kitchen / Under Cabinets' is On -) Then Set 'Kitchen / Coffee' Off Set 'Kitchen / Under Cabinets' On Else - No Actions - (To add one, press 'Action')
  3. I could not connect remotely via web browser.
  4. I tried to connect to my ISY at work today via my iPhone and my connection timed out. When I got home and was connected via WiFi everything was fine. I tried to again with 3g and nothing... I hopped on my neighbors WiFi andI could connect to the ISY homescreen via my https://20.30.xxx.xx... but couldn't nagigate to any of the scenes, devices, programs, etc... I saw some other threads about remote connection problems after a power outage so I reset my router and ISY...nothing. Then I unplugged my cable modem and plugged it back in again and DING DING DING! Everything is working fine. I guess my power went out last night during the storm? Is there anyway I can prevent from this happening again? Or is there another fix without manually resetting the cable modem? Sorry if this has been covered before. I've read a lot of the forums before trying the cable modem reset and didn't see anything. My ISY-99i software is up to date (2.7.15)
