mikerenna
Everything posted by mikerenna
  1. Any thoughts what that means? There are a number of devices with the same issue. Several are brand new. Doesn't the PLM use both power line and RF? Several of these devices worked fine with X10 so it would seem the installation is correct. Any ideas are appreciated on where to go from here.
  2. Fri 09/03/2010 06:35:28 PM : ---- Initializing the linked devices ---- Fri 09/03/2010 06:35:28 PM : ---- All Linked Devices are now initialized ---- Fri 09/03/2010 06:35:28 PM : ---- Add remaining devices ---- Fri 09/03/2010 06:35:28 PM : [ 8 28 75 1] Removing all links Fri 09/03/2010 06:35:28 PM : [8 28 75 1 ] Querying engine version Fri 09/03/2010 06:35:28 PM : [iNST-ACK ] 02 62 08.28.75 0F 0D 00 06 (00) Fri 09/03/2010 06:35:37 PM : [iNST-ACK ] 02 62 08.28.75 0F 0D 00 06 (00) Fri 09/03/2010 06:35:46 PM : [iNST-ACK ] 02 62 08.28.75 0F 0D 00 06 (00) Fri 09/03/2010 06:35:50 PM : [8 28 75 1 ] Failed getting engine version. Reverting to i1. Fri 09/03/2010 06:35:50 PM : [8 28 75 1 ] Using engine version i1 Fri 09/03/2010 06:35:50 PM : [iNST-ACK ] 02 62 08.28.75 0F 28 0F 06 SET-MSB(0F) Fri 09/03/2010 06:35:59 PM : [iNST-ACK ] 02 62 08.28.75 0F 28 0F 06 SET-MSB(0F) Fri 09/03/2010 06:36:08 PM : [iNST-ACK ] 02 62 08.28.75 0F 28 0F 06 SET-MSB(0F) Fri 09/03/2010 06:36:12 PM : [ 8 28 75 1] ** Not added ** Remove Device Links failed Fri 09/03/2010 06:36:12 PM : ---- All Remaining Device Added ----
  3. Fri 09/03/2010 03:27:00 PM : ---- Initializing the linked devices ---- Fri 09/03/2010 03:27:00 PM : ---- All Linked Devices are now initialized ---- Fri 09/03/2010 03:27:00 PM : ---- Add remaining devices ---- Fri 09/03/2010 03:27:00 PM : [ 8 28 75 1] Reading all links Fri 09/03/2010 03:27:22 PM : [8 28 75 1 ] Failed getting engine version. Reverting to i1. Fri 09/03/2010 03:27:44 PM : [ 8 28 75 1] ** Not added ** Read device links failed Fri 09/03/2010 03:27:44 PM : ---- All Remaining Device Added ---- Fri 09/03/2010 03:27:44 PM : ---- Start: Generate Scenes from links ---- Fri 09/03/2010 03:27:44 PM : ---- End: Generate Scenes from links ----
  4. The linking process, where i put it in linking mode and then go around hitting each device worked fine for the devices that i could add via the other method and failed for the ones that failed. Sure seems to point to some kind of communciation error perhaps. Not very familiar with how to read the logs. Will they tell me anything that would confirm where the breakdown is? Thanks for the fast reply btw.
  5. I've been scouring the forum for some time desperately trying to find a fix for why several of my insteon devices can not be added. I've moved the isy/plm around the house to no avail (interference suggestion). I have a number of devices that add fine and some that always return the failed to add the highwater mark error. For example a 2476S v2.5 adds fine but several brand new 2476S v5.6 will not add. I've tried resetting the devices by pulling out the bottom tab on the device for 5 seconds. (I used to use some X10 so trying to wipe any of that out if possible) i've tried putting them in programming mode before adding. I've tried removing and readding everything. The same devices add the added before and the same devices fail that failed before. I've ugraded isy to latest beta firmware I'm not sure where go in troubleshooting at this point. Any help would be appreciated. Mike Renna
