raaka
  1. Hi Michael, Yes, it's all good now, thanks a lot for your help! How can I tell what the firmware version of the PLM is? I did not see anything on the Admin Console. -ari
  2. Thanks a lot, got in using telnet port 126 : Please Log in Username:admin Password:***** Hi! Welcome to ISY Shell CT - Configure TCP/IP CL - Configure max log size LS - List files/directories SU - Show external url SM - Show memory utilization ST - Show system time DT - Disable telnet EI - Enable internet access XS - Exit the shell RS - Reboot the system RL - Reset login to admin/admin FR - Factory reset MN - Menu VE - Display Version DBG - Debug [0|1|2] http://192.168.0.103:60168/>INSTALLING NEW FIRMWARE CODE/insteon.img FIRMWARE SUCCESSFULLY UPDATED http://192.168.0.103>ve Product: (1020) ISY 99i 256 App: Insteon_UD99 Platform: ISY-C-99 Version: 2.7.15 Build Date: 2010-04-20-12:58:59 Other Services: - Programs Enabled
  3. Here's the ebay listing with two pics: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... &viewitem=
  4. How can I tell if this box is ISY-26 or ISY-99i? From the outside the box looks like this http://www.universal-devices.com/99i.htm, At the bottom the sticker says ISY-99i S/N #005393 However, the hostname is set to ISY26-HOME-AUTO for some reason. PLM 2412S was also part of the bundle.
  5. Hi there, I bought a used ISY-99i on eBay and I'm having trouble connecting to it. I plugged it to the router and I see DHCP assigned this IP to it: ISY26-HOME-AUTO 192.168.0.103 I can ping it but cannot telnet nor connect with browser to http://192.168.0.3 I did the reset to factory defaults, no change. Any pointers what to do? Thanks! -ari C:\>ping 192.168.0.103 Pinging 192.168.0.103 with 32 bytes of data: Reply from 192.168.0.103: bytes=32 time=37ms TTL=60 Reply from 192.168.0.103: bytes=32 time=2ms TTL=60 Reply from 192.168.0.103: bytes=32 time=3ms TTL=60 Reply from 192.168.0.103: bytes=32 time=2ms TTL=60 Ping statistics for 192.168.0.103: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 2ms, Maximum = 37ms, Average = 11ms
