cchriste@pmesavepro.ch
  1. hello again, the issue is not resolved, bur i have a dump java where we can see the problems. maybe this dump can contribute for a correction ? Best regards, Charles 3 dumps : fisrt : all caches cleared all : lanch the administrative console and click to Program Summary. Because i cant upload the file dumpjava.txt, i put them into "code" sorry. Java Plug-in 1.6.0_26 Utilisation de la version JRE 1.6.0_26-b03 Java HotSpot(TM) 64-Bit Server VM Répertoire d'accueil de l'utilisateur = /home/cchriste ---------------------------------------------------- c: effacer la fenêtre de la console f: finaliser les objets de la file d'attente de finalisation g: libérer la mémoire h: afficher ce message d'aide l: vider la liste des chargeurs de classes m: imprimer le relevé d'utilisation de la mémoire o: déclencher la consignation q: masquer la console r: recharger la configuration des politiques s: vider les propriétés système et déploiement t: vider la liste des threads v: vider la pile des threads x: effacer le cache de chargeurs de classes 0-5: fixer le niveau de traçage à ---------------------------------------------------- security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio. security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp security: property package.definition value null security: property package.definition new value com.sun.javaws security: property package.definition value com.sun.javaws security: property package.definition new value com.sun.javaws,com.sun.deploy security: property package.definition value com.sun.javaws,com.sun.deploy security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss basic: Récepteur de progression ajouté : sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@4c53ab04 basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/web/insteon.jar basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/WEB/CE.JAR basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/WEB/FP.JAR basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/web/chart.jar network: Entrée de cache introuvable [url : http://192.168.1.202:1202/web/insteon.jar, version : null] network: Connexion de http://192.168.1.202:1202/web/insteon.jar avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Téléchargement de la ressource : http://192.168.1.202:1202/web/insteon.jar Content-Length : 1'511'276 Content-Encoding: null network: CleanupThread used 85992 us network: Enregistrer l'URL http://192.168.1.202:1202/web/insteon.jar dans le fichier /home/cchriste/.java/deployment/cache/6.0/3/52371ac3-6561c295-temp security: Fichier de liste noire introuvable ou contrôle de révocation désactivé security: Fichier de liste de bibliothèques de confiance non trouvé network: CleanupThread used 2 us security: Accès aux clés et au certificat dans le profil utilisateur Mozilla : null security: Chargement des certificats AC racine depuis /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/security/cacerts security: Certificats AC racine chargés depuis /usr/lib/jvm/java-6-sun-1.6.0.26/jre/lib/security/cacerts security: Chargement des certificats JPI depuis /home/cchriste/.java/deployment/security/trusted.certs security: Certificats JPI chargés depuis /home/cchriste/.java/deployment/security/trusted.certs security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat network: Entrée de cache introuvable [url : http://crl.globalsign.net/Root.crl, version : null] network: Connexion de http://crl.globalsign.net/Root.crl avec proxy=DIRECT network: Connexion de http://crl.globalsign.net:80/ avec proxy=DIRECT network: CleanupThread used 3 us network: Téléchargement de la ressource : http://crl.globalsign.net/Root.crl Content-Length : 469 Content-Encoding: null network: Enregistrer l'URL http://crl.globalsign.net/Root.crl dans le fichier /home/cchriste/.java/deployment/cache/6.0/36/e4f6ea4-44908d0d-temp network: CleanupThread used 2 us network: Entrée de cache introuvable [url : http://crl.globalsign.net/primobject.crl, version : null] network: Connexion de http://crl.globalsign.net/primobject.crl avec proxy=DIRECT network: Connexion de http://crl.globalsign.net:80/ avec proxy=DIRECT network: CleanupThread used 3 us network: Téléchargement de la ressource : http://crl.globalsign.net/primobject.crl Content-Length : 460 Content-Encoding: null network: Enregistrer l'URL http://crl.globalsign.net/primobject.crl dans le fichier /home/cchriste/.java/deployment/cache/6.0/26/5bd0c21a-7f40e94d-temp network: CleanupThread used 3 us network: Entrée de cache introuvable [url : http://crl.globalsign.net/ObjectSign.crl, version : null] network: Connexion de http://crl.globalsign.net/ObjectSign.crl avec proxy=DIRECT network: Connexion de http://crl.globalsign.net:80/ avec proxy=DIRECT network: CleanupThread used 1 us network: Téléchargement de la ressource : http://crl.globalsign.net/ObjectSign.crl Content-Length : 15'668 Content-Encoding: null network: Enregistrer l'URL http://crl.globalsign.net/ObjectSign.crl dans le fichier /home/cchriste/.java/deployment/cache/6.0/36/4867e6a4-2e31a703-temp network: CleanupThread used 1 us security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: updateValidationResultsForApplet update cache: Mark prevalidated: http://192.168.1.202:1202/web/insteon.jar true tm=1316194675940 cert=1376760414000 security: Certificate revocation enabled. Disable security validation optimizations. security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: updateValidationResultsForApplet update cache: Mark prevalidated: http://192.168.1.202:1202/web/insteon.jar true tm=1316194675955 cert=1376760414000 basic: Plugin2ClassLoader.getPermissions CeilingPolicy allPerms network: Entrée de cache introuvable [url : http://192.168.1.202:1202/WEB/CE.JAR, version : null] network: Connexion de http://192.168.1.202:1202/WEB/CE.JAR avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: CleanupThread used 3 us network: Téléchargement de la ressource : http://192.168.1.202:1202/WEB/CE.JAR Content-Length : 108'018 Content-Encoding: null network: Enregistrer l'URL http://192.168.1.202:1202/WEB/CE.JAR dans le fichier /home/cchriste/.java/deployment/cache/6.0/3/6354b5c3-6216f447-temp security: Fichier de liste noire introuvable ou contrôle de révocation désactivé security: Fichier de liste de bibliothèques de confiance non trouvé network: CleanupThread used 2 us security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: updateValidationResultsForApplet update cache: Mark prevalidated: http://192.168.1.202:1202/WEB/CE.JAR true tm=1316194676508 cert=1376760414000 network: Entrée de cache introuvable [url : http://192.168.1.202:1202/WEB/FP.JAR, version : null] network: Connexion de http://192.168.1.202:1202/WEB/FP.JAR avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: CleanupThread used 2 us network: Téléchargement de la ressource : http://192.168.1.202:1202/WEB/FP.JAR Content-Length : 761'928 Content-Encoding: null network: Enregistrer l'URL http://192.168.1.202:1202/WEB/FP.JAR dans le fichier /home/cchriste/.java/deployment/cache/6.0/29/1fdd9e5d-724a8051-temp security: Fichier de liste noire introuvable ou contrôle de révocation désactivé security: Fichier de liste de bibliothèques de confiance non trouvé network: CleanupThread used 1 us security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: updateValidationResultsForApplet update cache: Mark prevalidated: http://192.168.1.202:1202/WEB/FP.JAR true tm=1316194678823 cert=1376760414000 network: Entrée de cache introuvable [url : http://192.168.1.202:1202/web/chart.jar, version : null] network: Connexion de http://192.168.1.202:1202/web/chart.jar avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: CleanupThread used 2 us network: Téléchargement de la ressource : http://192.168.1.202:1202/web/chart.jar Content-Length : 964'212 Content-Encoding: null network: Enregistrer l'URL http://192.168.1.202:1202/web/chart.jar dans le fichier /home/cchriste/.java/deployment/cache/6.0/29/61b2f25d-1a1cd7fb-temp security: Fichier de liste noire introuvable ou contrôle de révocation désactivé security: Fichier de liste de bibliothèques de confiance non trouvé network: CleanupThread used 1 us security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: updateValidationResultsForApplet update cache: Mark prevalidated: http://192.168.1.202:1202/web/chart.jar true tm=1316194681502 cert=1376760414000 network: Entrée de cache introuvable [url : http://192.168.1.202:1202/, version : null] network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Firewall authentication: site=/192.168.1.202:1202, protocol=http, prompt=/, scheme=basic network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors.properties avec proxy=DIRECT security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: Applet chargé. basic: Applet resized and added to parent container basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 72904 us, pluginInit dt 30777652 us, TotalTime: 30850556 us network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors.properties avec proxy=DIRECT basic: Applet initialized basic: Récepteur de progression supprimé : sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@4c53ab04 basic: Applet made visible basic: Starting applet basic: completed perf rollup basic: Applet started basic: Told clients applet is started network: Entrée de cache introuvable [url : http://www.universal-devices.com/auto_update/updates_config, version : null] network: Connexion de http://www.universal-devices.com/auto_update/updates_config avec proxy=DIRECT network: Connexion de http://www.universal-devices.com:80/ avec proxy=DIRECT network: CleanupThread used 2 us network: Téléchargement de la ressource : http://www.universal-devices.com/auto_update/updates_config Content-Length : 57 Content-Encoding: null network: Enregistrer l'URL http://www.universal-devices.com/auto_update/updates_config dans le fichier /home/cchriste/.java/deployment/cache/6.0/59/271b51bb-27adf958-temp network: CleanupThread used 2 us network: Entrée de cache introuvable [url : http://www.homeorchestrator.com/updates/prod-updates.xml, version : null] network: Connexion de http://www.homeorchestrator.com/updates/prod-updates.xml avec proxy=DIRECT network: Connexion de http://www.homeorchestrator.com:80/ avec proxy=DIRECT network: CleanupThread used 3 us network: Téléchargement de la ressource : http://www.homeorchestrator.com/updates/prod-updates.xml Content-Length : 12'342 Content-Encoding: null network: Enregistrer l'URL http://www.homeorchestrator.com/updates/prod-updates.xml dans le fichier /home/cchriste/.java/deployment/cache/6.0/61/263ea1bd-5e610130-temp network: CleanupThread used 2 us network: Entrée de cache introuvable [url : http://www.homeorchestrator.com/UDStore/ServiceProductModules?uuid=uuid:00:21:b9:01:0b:0e, version : null] network: Connexion de http://www.homeorchestrator.com/UDStore/ServiceProductModules?uuid=uuid:00:21:b9:01:0b:0e avec proxy=DIRECT network: Connexion de http://www.homeorchestrator.com:80/ avec proxy=DIRECT security: Certificate revocation enabled. Disable security validation optimizations. security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: updateValidationResultsForApplet update cache: Mark prevalidated: http://192.168.1.202:1202/WEB/CE.JAR true tm=1316194742300 cert=1376760414000 basic: Plugin2ClassLoader.getPermissions CeilingPolicy allPerms java.lang.StringIndexOutOfBoundsException: String index out of range: 13095 at java.lang.String.substring(String.java:1934) at com.universaldevices.soap.UDHTTPResponse.parse(Unknown Source) at com.universaldevices.soap.UDHTTPRequest.getServerResponse(Unknown Source) at com.universaldevices.soap.UDSOAPRequest.submit(Unknown Source) at com.universaldevices.soap.UDSOAPRequest.submit(Unknown Source) at com.universaldevices.upnp.UDProxyDevice.submitSOAPRequest(Unknown Source) at com.universaldevices.upnp.UDProxyDevice.submitSOAPRequest(Unknown Source) at com.universaldevices.upnp.UDProxyDevice.loadTriggers(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerPlatformISY.loadTriggers_Internal(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerPlatformISY.access$0(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerPlatformISY$1.run(Unknown Source) at java.lang.Thread.run(Thread.java:662) basic: Starting applet teardown basic: Finished applet teardown basic: Récepteur de progression ajouté : sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@31eeeaed basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/web/insteon.jar basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/WEB/CE.JAR basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/WEB/FP.JAR basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/web/chart.jar network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors.properties avec proxy=DIRECT security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: Applet chargé. basic: Applet resized and added to parent container basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 72904 us, pluginInit dt 170960216 us, TotalTime: 171033120 us network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors.properties avec proxy=DIRECT basic: Applet initialized basic: Récepteur de progression supprimé : sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@31eeeaed basic: Applet made visible basic: Starting applet basic: completed perf rollup basic: Applet started basic: Told clients applet is started network: Entrée de cache introuvable [url : http://www.homeorchestrator.com/UDStore/ServiceProductModules?uuid=uuid:00:21:b9:01:0b:0e, version : null] network: Connexion de http://www.homeorchestrator.com/UDStore/ServiceProductModules?uuid=uuid:00:21:b9:01:0b:0e avec proxy=DIRECT network: Connexion de http://www.homeorchestrator.com:80/ avec proxy=DIRECT Exception in thread "AWT-EventQueue-3" java.lang.NullPointerException at com.universaldevices.ui.sysconfig.notifications.NotificationsPanel.addNotificationChangeListener(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerDevice.(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerInsteonDevice.(Unknown Source) at com.universaldevices.client.ui.UDClientApplet.newTriggerDevice(Unknown Source) at com.universaldevices.ui.views.TriggerView.refresh(Unknown Source) at com.universaldevices.ui.UPnPClientApplet$6.stateChanged(Unknown Source) at javax.swing.JTabbedPane.fireStateChanged(JTabbedPane.java:400) at javax.swing.JTabbedPane$ModelListener.stateChanged(JTabbedPane.java:253) at javax.swing.DefaultSingleSelectionModel.fireStateChanged(DefaultSingleSelectionModel.java:116) at javax.swing.DefaultSingleSelectionModel.setSelectedIndex(DefaultSingleSelectionModel.java:50) at javax.swing.JTabbedPane.setSelectedIndexImpl(JTabbedPane.java:599) at javax.swing.JTabbedPane.setSelectedIndex(JTabbedPane.java:574) at javax.swing.plaf.basic.BasicTabbedPaneUI$Handler.mousePressed(BasicTabbedPaneUI.java:3628) at java.awt.Component.processMouseEvent(Component.java:6285) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6053) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4651) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4481) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4235) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Window.dispatchEventImpl(Window.java:2478) at java.awt.Component.dispatchEvent(Component.java:4481) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:643) at java.awt.EventQueue.access$000(EventQueue.java:84) at java.awt.EventQueue$1.run(EventQueue.java:602) at java.awt.EventQueue$1.run(EventQueue.java:600) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87) at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:98) at java.awt.EventQueue$2.run(EventQueue.java:616) at java.awt.EventQueue$2.run(EventQueue.java:614) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87) at java.awt.EventQueue.dispatchEvent(EventQueue.java:613) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122) basic: Starting applet teardown Disposal was interrupted: java.lang.InterruptedException at java.lang.Object.wait(Native Method) at java.lang.Object.wait(Object.java:485) at java.awt.EventQueue.invokeAndWait(EventQueue.java:1037) at java.awt.Window.doDispose(Window.java:1030) at java.awt.Window.dispose(Window.java:973) at com.universaldevices.common.ui.GUISystem.Stop(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.stop(Unknown Source) at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Plugin2Manager.java:1788) at java.lang.Thread.run(Thread.java:662) java.lang.NullPointerException at com.universaldevices.ui.sysconfig.notifications.NotificationsPanel.stop(Unknown Source) at com.universaldevices.ui.sysconfig.notifications.NotificationsTab.stop(Unknown Source) at com.universaldevices.ui.views.SystemConfigurationView.stop(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.stop(Unknown Source) at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Plugin2Manager.java:1788) at java.lang.Thread.run(Thread.java:662) basic: Finished applet teardown basic: Récepteur de progression ajouté : sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@34adcae8 basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/web/insteon.jar basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/WEB/CE.JAR basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/WEB/FP.JAR basic: Plugin2ClassLoader.addURL parent called for http://192.168.1.202:1202/web/chart.jar network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr_CH.properties avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/udi/insteon/client/InsteonErrors.properties avec proxy=DIRECT security: Chargement des certificats depuis la zone de stockage des certificats de session JPI security: Certificats chargés depuis la zone de stockage des certificats de session JPI security: Validez la chaîne de certificats à laide de lAPI CertPath security: Obtenez la collection de certificats du magasin de certificats Root CA security: Obtenez la collection de certificats du magasin de certificats Root CA security: Aucune information d'horodatage disponible security: Fichier de liste de juridiction trouvé security: Démarrer la vérification de l'extension de confiance pour ce certificat security: Démarrer la comparaison à la liste de juridiction avec ce certificat security: La prise en charge de LRC est activée. security: Universal Devices, Inc. security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign ObjectSign CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: GlobalSign Primary Object Publishing CA security: ObjectId: 2.5.29.31 Criticality=false CRLDistributionPoints [ [DistributionPoint] ]] security: Ce certificat na pas dextension LRC security: Utilisez le paramètre LRC contenu dans le certificat security: La prise en charge de OCSP est activée. security: Universal Devices, Inc. security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/ObjectSign.crt] ] security: GlobalSign ObjectSign CA security: ObjectId: 1.3.6.1.5.5.7.1.1 Criticality=false AuthorityInfoAccess [ [ accessMethod: 1.3.6.1.5.5.7.48.2 accessLocation: URIName: http://secure.globalsign.net/cacert/PrimObject.crt] ] security: Ce certificat na pas dextension AIA security: Ce certificat na pas dextension AIA security: Utilisez le paramètre OCSP contenu dans le certificat security: Validation du certificat réussie à laide de lOCSP/CRL security: Cette validation de lentité finale OSCP est désactivée security: Vérification de la présence du certificat dans le magasin Deployment de certificats refusés security: Recherche du certificat dans le magasin de certificats permanent JPI basic: Applet chargé. basic: Applet resized and added to parent container basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 72904 us, pluginInit dt 300787855 us, TotalTime: 300860759 us network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/LibErrors.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/PlatformErrors.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr_CH.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/errormessages/SMTPErrors.properties avec proxy=DIRECT basic: Applet initialized basic: Récepteur de progression supprimé : sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@34adcae8 basic: Applet made visible basic: Starting applet basic: completed perf rollup basic: Applet started basic: Told clients applet is started Exception in thread "AWT-EventQueue-4" java.lang.NullPointerException at com.universaldevices.ui.sysconfig.notifications.NotificationsPanel.addNotificationChangeListener(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerDevice.(Unknown Source) at com.universaldevices.ui.d2d.UDTriggerInsteonDevice.(Unknown Source) at com.universaldevices.client.ui.UDClientApplet.newTriggerDevice(Unknown Source) at com.universaldevices.ui.views.TriggerView.refresh(Unknown Source) at com.universaldevices.ui.UPnPClientApplet$6.stateChanged(Unknown Source) at javax.swing.JTabbedPane.fireStateChanged(JTabbedPane.java:400) at javax.swing.JTabbedPane$ModelListener.stateChanged(JTabbedPane.java:253) at javax.swing.DefaultSingleSelectionModel.fireStateChanged(DefaultSingleSelectionModel.java:116) at javax.swing.DefaultSingleSelectionModel.setSelectedIndex(DefaultSingleSelectionModel.java:50) at javax.swing.JTabbedPane.setSelectedIndexImpl(JTabbedPane.java:599) at javax.swing.JTabbedPane.setSelectedIndex(JTabbedPane.java:574) at javax.swing.plaf.basic.BasicTabbedPaneUI$Handler.mousePressed(BasicTabbedPaneUI.java:3628) at java.awt.Component.processMouseEvent(Component.java:6285) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6053) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4651) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4481) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4235) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Window.dispatchEventImpl(Window.java:2478) at java.awt.Component.dispatchEvent(Component.java:4481) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:643) at java.awt.EventQueue.access$000(EventQueue.java:84) at java.awt.EventQueue$1.run(EventQueue.java:602) at java.awt.EventQueue$1.run(EventQueue.java:600) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87) at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:98) at java.awt.EventQueue$2.run(EventQueue.java:616) at java.awt.EventQueue$2.run(EventQueue.java:614) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87) at java.awt.EventQueue.dispatchEvent(EventQueue.java:613) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122) network: Entrée de cache introuvable [url : http://www.homeorchestrator.com/UDStore/ServiceProductModules?uuid=uuid:00:21:b9:01:0b:0e, version : null] network: Connexion de http://www.homeorchestrator.com/UDStore/ServiceProductModules?uuid=uuid:00:21:b9:01:0b:0e avec proxy=DIRECT network: Connexion de http://www.homeorchestrator.com:80/ avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/nls/UDNLS_fr_CH.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/nls/UDNLS_fr_CH.properties avec proxy=DIRECT network: Connexion de http://192.168.1.202:1202/ avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/nls/UDNLS_fr.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/nls/UDNLS_fr.properties avec proxy=DIRECT network: Entrée de cache introuvable [url : http://192.168.1.202:1202/com/universaldevices/resources/nls/UDNLS.properties, version : null] network: Connexion de http://192.168.1.202:1202/com/universaldevices/resources/nls/UDNLS.properties avec proxy=DIRECT
  2. Hello, I'm back... Sorry for the delay. when i say "old" programs, they are the program in the I99 before i upgrade the i99. at this time, all programs runnings well, but effectively, all tabs "programs" are blank. Why when i open the administrative console form chrome/IE/Firefox/etc.. i can see the contents of this tabs and better, i can make update the visual difference is : on chrome/Firefox Linux : the progress bar of the box "load program" stop after 3 seconds and all tabs blank. With chrome/IE/Firefox XP : the progress bar of the box "load program" stop after 7 seconds and all tabs are filled well. would you like the address for make test by yourself ? Best Regards, Charles
  3. Hi Michel, sorry for the delay. When the port 443 forwarded (nat) i can access the isy trough the admin.jnlp. But its the same, when i click on the program summary, the load dialog turn for aprox 3 second and quit. But no program to see. I can create a new one. i didn't save it because i dont like to find an unpredictable result. I made an fresh ubuntu vm, when i want to connect to the isy admin console, i have to install java 2+., after the install of java 6. I restart the browser and i could connect to the isy. But the same... no access to "old" programs. With any other xp vm or not, it's work fine. Would you access to my Isy to try by your self ? Best regards, Charles
  4. Hi Michel, from the LAN, yes, immediately and fully. But the pc is xp. I'ts work fine too from the "standard interface". from the WAN (my case now the isy is in Florida, i'm in Switzerland), From linux or xp, when I click "add", I put my ip:port or url:port, i get an invalid url back. Sorry to spend your time... Best regard, good we. Charles
  5. Hi Michel, Tank you for your interest about my problem. I'm sorry, but before i wrot my initial post, i have already try your suggestion. Infortunatly, the problem was the same. If I can, this evening (gmt+1) I try in a new ubuntu vm just to be sure it's regarding java and cache. All, thank you for your help and time an have a nice day, Best regards Charles
  6. Hello, after the upgrade to 2.8.16, on my linux pc, i couldn't access any more the programs. But, when in an vm xp i have the access to all programs. The java cache is cleared. I read many many post, i didnt' find nothing to help me. Is some one have an idea to guide me ? Many thanks. Charles
