ML
Everything posted by ML
  1. Thanks fitzpatri8! Yes, its a brand new unit and brand new PLM (2413s). I did test the PLM before I started and access point test was no problem (just did it again, no issues). But I never reach step 2 in your post. When I click "Start Linking" I get this error message ("Discovering Nodes. Retry"). In fact at that point, even if I change tabs (e.g. to Program Details) I get that message. Even if I disconnect the PLM I get that message. I did try setting an INSTEON device to linking mode and same issue (no blinking on ISY, just the error message). I factory reset the PLM (powered off for 30 seconds, held button down and powered up, released button after 10 seconds). To no avail. Maybe relevant: Also the ISY admin console keeps asking me for password ("My Lighting authentication" box pops up) every 15-20 seconds. Since the password is already filled in, I just hit OK and it goes away... for 15 more seconds. But I know I am connected to the ISY and authenticated since I can see stuff like SD card status, NTP server I saved etc., just keeps losing the session for some reason. I switched from WiFi to an ethernet LAN connection just in case it was the WiFi but again, still has the annoying popup. Any ideas? Thanks in advance, ML
  2. Hi, I finally got around to opening up my ISY and followed the steps to configure it up to the step where it said to use "Start Linking" under the LinkManagement menu. When I do that I keep getting this error "Error Discovering Nodes. Retry". I tried powering off the ISY, the PLM and restarted the Java app - everything seems Ok until I start linking and after that even changing tabs in the Java interface brings up this message. Any idea what is happening? Logging off and back on doesn't fix it, so I assume the ISY or the PLM is busy with something. If so, how long do i wait? I did wait about 20 mins in case it was doing some discovery but to no avail. I have 30 or so INSTEON devices on the network and was using them with manual links earlier (controlled by SmartLinc) in case that helps. The ISY and PLM are brand new in factory fresh condition. Thanks in advance. ML.
  3. Hi Michel, Thanks for your very candid reply. On the PRO part, I am already planning for that since I am a software engineer by profession and I expect to use it beyond the non-PRO limits (and with the optional modules I might add, for which I already have plans). My question was only about IR since I already have the IRlinc receiver. ALso, I assumed it was a hardware upgrade so I didn't want to get something and have to replace the unit later. Sounds from your email that it isn't, which is great. I will probably go with the non-IR and spring for the additional IR functionality only if I find something beyond the IRLinc. I'll put my Touchswitch questions on their forum. Thanks again - your prompt responses to the forum members were a big factor in my deciding to go with ISY. Its always a pleasure working with products that people stand behind. I'm sure I'll have a lot more questions as I start using it. Cheers, ML
  4. Hi, I just got done setting up a bunch of INSTEON devices in my home and except for the lame SmartLinc that I bought based on the marketing, I am happy with the INSTEON part so far. Based on the glowing reviews of ISY-99i I think it might be the thing I was looking for. I am planning to ditch the SmartLinc and buy the ISY PRO version since it gives me headroom for the future but I am wondering if I need to consider the IR version, especially since I already have an IRLinc, or I can do without the IR. Also browsing through some of the forum posts, I found it interesting that folks recommended that I should buy the Touchswitch software first so I can get the discounted network module (I would have definitely not thought about even evaluating a front-end first before getting the nw module, so I am happy I read the posts first). Any other tips along these lines from anyone for add-ons to the ISY? Last, does the Touchswitch support IP cameras (I have some panasonic IP cameras already installed) or should I be looking for another option if I need an integrated GUI (especially on my iPhone) for the HA and cams together? Also, if anyone who has used the Touchswitch could respond - is it a web-app on the iPhone or does it install a native iPhone app piece too? Thanks in advance - I haven't even bought my ISY and this forum has been ultra-helpful already. ML
