ron
  1. I have several mutli-way switches linked properly and work just fine. In most cases the muti-way switches are located at different floor levels, and I want a way to trigger scenes that would turn off lights at the remote floors in the house. Thought it would useful to use "Fast Off" as a trigger to run a program to do this. Depending upon which switch on which floor the proper program would do the desired action. Problem is that only one of the SwitchLinc's is visible in the multi-way scene via IF Control. One thing I am doing that may be at issue is the SwitchLinc dimmer us used for the load but a ICON dimmer for the isolated n-way switches. I do know the ISY sees the "Fast Off" from all devices via the event logger. It's a matter of why all devices are not accessible via IF Control. Am I doing something wrong here or is there a compatibility issue mixing different devices in a n-way setup?
