stre1026
  1. Weird, I'm only getting 2 per node and neither one has a color change option.
  2. stre1026 posted a topic in eisy
    I was able to attach my Hue bulbs to EISY via the USB Z-matter dongle. I can turn them on and off, but I can't see how to change their color. I'd especially like to do this via scenes. Is this possible? I did use the app and changed the device type to Hue but that doesn't do anything. I get an error that says "can't get main node hue" or something like that when I try to change the colors. Am I missing something? I was trying to avoid using the Hue Hub and Polyglot but I may have to go that route.
  3. Just a shot in the dark, but are you having DNS issues with the ISY reaching out to DNS servers?
  4. Has anything changed drastically in 5.3.3 from 5.3.0? This program has been working perfectly fine as is for years.
  5. I upgraded to 5.3.3 and had an issue with my Z-wave door locks. For some reason, they stopped reporting user numbers so the programs that I had fire based on the user number unlocking the door didn't work anymore. I downgraded back to 5.3.0 and the problem went away so I imagine it might be a bug in 5.3.3? The program looks like this: Side Door - Alarm Disarm - [ID 0005][Parent 0003] If 'Locks / ZW Side Door Lock' User Number is 1 Or 'Locks / ZW Side Door Lock' User Number is 2 And 'Locks / ZW Side Door Lock' is switched Alarm Unlocked by Keypad Then Set Elk Area 'House' Disarm Set 'Kitchen / Kitchen Recessed' On Set 'Thermostats-Home' On Else - No Actions - (To add one, press 'Action')
  6. I had a lot of issues with my BE469 locks initially. Which firmware are you running on the locks? I have locks with 5.6 and 5.8 versions of the firmware and they work much better. As for range extenders, I've had very good luck with the latest Aeotec range extenders. They are version 5 or something. My ISY is in the basement and I have one BE469 lock on my front door that's about 40 feet away from the ISY with a range extender in the middle and it works 100% of the time. I'm also running the latest 500 Z-wave module in my ISY. Hope this info helps.
  7. stre1026 replied to stre1026's topic in ISY994
    The ELK sends every motion. I have the variable updating quite quickly.
  8. stre1026 posted a topic in ISY994
    So I have a situation that I'm sure many of you have... I have kids that like to leave lights on all around the house. What I would like to do is start a timer based on the motion sensor tied to my ELK security system in the kids playroom. So when the turn the lights on, it will start a timer for say 5 minutes and if there is motion detected, it will extend that another 5 minutes. I'm trying to wrap my head around the best way to do this. I have state variables setup and a program that updates the motion state variable to 1 if it detects motion and 0 when the motion stops. However, I'm not sure of the best way to implement the timer. I'm stuck on how to best implement the rest. Any thoughts would be greatly appreciated!
  9. stre1026 replied to stre1026's topic in ISY994
    Indeed. This is interesting. I didn't know that about the 500 series. The Z-wave module I replaced was actually one of the beta modules and it had an external antenna. The new one does not. I will try and buy a few new repeaters and see if that helps!
  10. stre1026 replied to stre1026's topic in ISY994
    The test device will stay near the ISY for testing which is why I did the network heal after I moved it. I think I will try and purchase a few new repeaters to see if that helps. They did support beaming at the time but maybe one of them went bad. Who knows. They are cheap enough to replace to see if that solves my issue.
  11. stre1026 replied to stre1026's topic in ISY994
    I'm aware of the ramifications of moving a device and healing the network. I was still talking about the test lock that I have. All of these devices and repeaters have been installed in my house for over 7 years at this point and all has been working perfectly fine until I upgraded to 5.x. This is why I was thinking this may be software related and not hardware. The only thing I have done hardware related is replaced the z-wave dongle in my ISY which required a rebuild of the network. This could of course caused issues in itself.
  12. stre1026 replied to stre1026's topic in ISY994
    Are there different revisions of Z-wave repeaters? I'm just thinking, the ones I have are pretty old. I'm wondering if I should swap them out with newer ones if this is a signal issue?
  13. stre1026 replied to stre1026's topic in ISY994
    The batteries are brand new and are at 100%. I will put the lock near the ISY itself and do a network heal to see if that helps.
  14. stre1026 replied to stre1026's topic in ISY994
    It's not but, I have plenty of repeaters and the lock will unlock/lock every time so I'm pretty sure signal is fine. The one installed in the door is acting the same exact way so I don't think it's related to the Z-wave network.
  15. stre1026 replied to stre1026's topic in ISY994
    I've been playing with this for a better portion of the day. I actually configured a spare lock on my ISY so I can play with this on a bench. What I'm finding is that the user number is not always recognized by the ISY. This is most likely the cause of my issue. I'm assuming this may be a version 5.x bug because I was able to consistently read the user number on the 4.x release.
