raptor
Everything posted by raptor
  1. Is there no replace function for 8 button keypads? If I right click on regular switches there's a "replace device with" option. Not seeing it that on keypads. Is the only only option to reprogram the?
  2. raptor replied to raptor's topic in ISY994
    Everything thing is back up and running. Seems to operate as it should. Thanks for the help.
  3. raptor replied to raptor's topic in ISY994
    I do have a power supply from and old router that is 5V 1 Amp would this work?
  4. raptor posted a topic in ISY994
    My PLM 2412s just failed so I ordered a PLM 2413S as the 2412 is no longer available. My 2412 was connected to my ISY via CAT5 cable. The new 2413S came with a cable that is RJ45 on one end and serial connector the other end. Should this be connected with the serial on the back of the ISY or should I connect the same way the 2412 was with just a CAT5 cable. Also since this is a replacement and not a new install is there a specific way to swap it and not lose any connection info.
  5. raptor replied to raptor's topic in ISY994
    That's the way In was doing it but this time for device type I put the actual device instead of auto discover and it worked.
  6. raptor replied to raptor's topic in ISY994
    I just checked and they are on opposite phases
  7. raptor replied to raptor's topic in ISY994
    I have 2-2443 access points
  8. raptor replied to raptor's topic in ISY994
    I can see to find were to upgrade the firmware. I've done it before but can't remember how
  9. raptor replied to raptor's topic in ISY994
    Also have a 2443. Should that one work because I tried putting beside it but nothing. I'm running the 99i so I guess I'm out of luck with the door sensor.
  10. raptor replied to raptor's topic in ISY994
    I factory reset the motion sensor, put it in pairing mode and put it a few inches from the PLM (2412s) . Try to re add it Wed 12/24/2014 05:10:26 PM : [31 B1 8F ] Added to list of devices to link to ISY Wed 12/24/2014 05:10:26 PM : [iNST-TX-I1 ] 02 62 31 B1 8F 0F 0D 00 Wed 12/24/2014 05:10:26 PM : [iNST-ACK ] 02 62 31.B1.8F 0F 0D 00 06 (00) Wed 12/24/2014 05:10:35 PM : [iNST-TX-I1 ] 02 62 31 B1 8F 0F 0D 00 Wed 12/24/2014 05:10:35 PM : [iNST-ACK ] 02 62 31.B1.8F 0F 0D 00 06 (00) Wed 12/24/2014 05:10:44 PM : [iNST-TX-I1 ] 02 62 31 B1 8F 0F 0D 00 Wed 12/24/2014 05:10:44 PM : [iNST-ACK ] 02 62 31.B1.8F 0F 0D 00 06 (00) Wed 12/24/2014 05:10:48 PM : [31 B1 8F 0 ] Failed to add device Wed 12/24/2014 05:12:09 PM : [iNST-TX-I1 ] 02 62 1D B1 E6 0F 11 FF Wed 12/24/2014 05:12:09 PM : [iNST-ACK ] 02 62 1D.B1.E6 0F 11 FF 06 LTONRR (FF) Wed 12/24/2014 05:12:09 PM : [iNST-SRX ] 02 50 1D.B1.E6 0F.42.41 27 11 FF LTONRR (FF) Wed 12/24/2014 05:12:09 PM : [std-Direct Ack] 1D.B1.E6-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
  11. raptor posted a topic in ISY994
    I'm trying to add 2 new sensors to my ISY but keep getting errors. When adding 2842 motion sensor I got cannot determined insteon engine at first but now getting cannot determine devices type. And when adding Insteon hidden door switch I get cannot determine Insteon devices type. I make sure they are in pairing mode and place them inches from the ISY
  12. Do you mean add it to the exception list? I removed it from the list and added it again but still get the same error message.
  13. Windows and yes it's a static IP. With the same IP set for the exception I can get to the web interface just can't get open the admin consol
  14. I have the same problem. I updated Java and added my IP to the exception list but still get application blocked for security
  15. raptor replied to raptor's topic in ISY994
    Thanks LeeG it works.
  16. raptor posted a topic in ISY994
    I have a Dakota Alert DCR-2500 Wireless Receiver and DCMT-2500. How do I wire the transmiter to a I/O Linc 2450. I want to prgram some scenes in the ISY trigered by motion. On the transmiter their are 3 plugs for each channels. The 3 plugs are NO, COM and NC. Were do I connect these on the I/O Link. And in the ISY the I/O link currently shows status of on or off. Will this work for what I want to do or do I have to configure something diffrently.
  17. raptor replied to raptor's topic in ISY994
    Thanks for the reply but could you expand on your answer. As a newbie what do i need to get this to work
  18. raptor replied to raptor's topic in ISY994
    Yes I do have a ISY 99.Just wasn't aware that one device could be configured as a controller in one scene and responder in another scene.
  19. raptor replied to raptor's topic in ISY994
    Currently I have no Zwave products except the deadbolts. So there no way to integrate with ISY
  20. raptor posted a topic in ISY994
    I have 3 Kwikset ZWave Motorized Deadbolt installed in my house. Only after installing them I actually realized that these had the potential to be controlled remotely. For this I believe I need some kind of wireless card to plug in the deadbolt. What exactly do I need and will I be able to control it try my ISY and Insteon switches.
  21. raptor replied to raptor's topic in ISY994
    I wasn't aware that the same button could be configured as controller in one seen and responder in another. I'll try that tonight and if it works it's going to be a lot of programing considering I have 4 keypad with eight buttons each but an easy fix. Thank You
  22. raptor replied to raptor's topic in ISY994
    I have four keypads. Lets call the keypad A-B-C-D. Lets say i turn on scene A on keypad A it also turns on the light inside button A on keypad A. If i go to any keypad A-B-C or D and push the all of button it will turn off all the lights in the house but the light that that's inside button A on keypad A stays on. This creates to problems. 1 once all the lights are off I still have keypad buttons that are glowing. 2 the next morning when I go to turn on a scene that's off but the keypad button is still on I have to push the button twice. Once turns of the button itself and does noting to the lights and the second time it turns on the button and the scene. Hope this clears it up for you.
  23. raptor posted a topic in ISY994
    I have 4 keypads in the house and anytime I push all of on any off them it turns all the lights off but if any keypad buttons are one(the light behind the button) it doesn't turn it off. I tried adding those keypad button to the all of scene but to do that I need to change the keypad from a controller to a responder. If I do this the keypad will no longer work as a controller right? Any way to fix this issue.
